Old December 16, 2008, 08:54 PM
CTA's Avatar
CTA CTA is offline
Default overclock software for old computer
i wonder is it okay to use overclock software for GIGABYTE - Product - Motherboard - Overview - GA-8SQ800 because BIOS sucks... no advance options...
intel p4 2.4ghz with stock ( ~26C degree idling...
2gb mushkin pc3200
truetrio 650
bfg 7800gs
i also would like to know max voltage and temperature for 2.4ghz ( old intel product database didn't tell)
thank you in advance...
Defragmenting Software miggs78 O/S's, Drivers & General Software 16 October 8, 2008 10:29 PM
Any divice or software that can do this.... Gameplaywarrior HTPC Systems & Software 3 October 4, 2008 10:44 AM
Software WolfBane Networking 11 August 1, 2008 12:28 PM
Question regarding software 3.0charlie HardwareCanucks F@H Team 2 June 29, 2007 09:06 AM
