  #31 (permalink)
Old January 12, 2010, 04:15 PM
sswilson's Avatar
Maybe I'm looking in the wrong places, but I can't for the life of me find a tool for the job.......
Is there a gfx stress test that will allow me to switch between different (non-sli'd) gpus in a multi-gpu rig? If so.... does it matter if I have a monitor plugged in to the card (I'm guessing this might be my problem..... I can use GPU Caps and it has the option of switching between GPUs, but it still only seems to run on the gpu that's connected..........)
  #32 (permalink)
Old January 13, 2010, 04:47 PM
sswilson's Avatar
NyBody?????
Is installing individual cards the only way to do this?
  #33 (permalink)
Old January 13, 2010, 04:59 PM
3.0charlie's Avatar
Having no monitor or dummy plug is probably your issue; as far as other apps, don't know of any.
  #34 (permalink)
Old January 13, 2010, 05:01 PM
Arinoth's Avatar
Test fold on it, if you get EUEs then the OC is too high and back it off, or if its the same card/model as the main just match it and bump it up or down a step until no EUEs
  #35 (permalink)
Old January 13, 2010, 05:08 PM
sswilson's Avatar
Heh... that's what I'm trying to avoid....
If I do my initial stress testing on normal WUs, it's bad science if it craps out. If I force it to do older WUs (expired) for testing purposes, I lose that potential PPD. :)
3.0Charlie... are you saying that you've been able to stress individual cards in a multi card setup? If so, what apps were you using?
  #36 (permalink)
Old January 13, 2010, 05:15 PM
3.0charlie's Avatar
No; I said I don't know of any other app than the one you mentionned that could test individual GPUs. Now, if you need dummy plugs, I have enough to fill all your adaptors. Let me know.
  #37 (permalink)
Old January 13, 2010, 05:30 PM
sswilson's Avatar
Thanks for the offer, but I've got enough monitors / monitor inputs to cover the 4 cards. Guess I'm just going to have to bite the bullet and do my own research on this.... ;)
  #38 (permalink)
Old January 13, 2010, 07:15 PM
Stanford will just resend the unit if it doesn't get folded properly. Not a big deal. Just think of all the extra science you'll be accomplishing once you find your max overclock ;).
  #39 (permalink)
Old April 2, 2010, 07:22 PM
maybe these would be good to make the list a bit more 2010 worthy
msi afterburner > MSI Afterburner
cpu-tweaker > Tweakers.fr
realtemp > Real Temp - CPU temperature monitoring
linx > LinX - A simple Linpack interface - XtremeSystems Forums
maxxpi suite > MaxxPI² - Introducing
cinebench > MAXON - The makers of CINEMA 4D and BodyPaint 3D
  #40 (permalink)
Old February 5, 2011, 08:51 PM
Default voltage
whats the best program for voltage monitoring
