Old December 7, 2008, 11:34 AM
rjbarker's Avatar
Put a good cooler on that thing and pump those volts to 1.42v and go for it. Don't forget to bump your nb voltage a bit and make sure to increase your vTT.
As Enab states don't be afraid to push that vCore up. As for your nb, may or not help pushing it up slightly from what your "Auto" will set it at, but watch the nb Temps if you do, personally I didn't have much luck with lowering vCore by raising nb.
As for your vTT - Auto will set it at 1.3v which is plenty for a 1800 FSB, no need to go to 1.4v. Some folks are schieving thier OC's with vTT set to 1.2v by making adjustments to their GTLREF Lanes, however the process, from what I read is quite long and drawn out to find the optimal xx mV to set the Lanes at....default is "Auto"
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old December 21, 2009, 06:53 PM
BIGFREAK's Avatar
Man Great info.
I have been running 3.6 for along time I have an e8400 c0
I have tryed all I have read and can't crack 4.0G :(
trying a 3825 FSB at 425
EVGA 750i FTW mobo
Old January 8, 2010, 07:45 PM
Hav you done the vdroop pencil mod for this mb . Mine was bad a few passes with the pencil and it all went away . I run 500fsb 90% of the time
E8400 E0 4275 (66 hours orthos stable) @ 1.38v 50deg load /Xfx 780i / 4 GIGz Balistix 6400 / Corsair 620hx / 8800gt @ 740/1800/1000 / Water Cooling
Old January 8, 2010, 07:53 PM
Oh and for benching I was able to hit 4.95 for a high and some benching @ 4.7-4.8
