Old December 5, 2008, 05:44 PM
dadzilla's Avatar
Default Noobi OC question
Hello OC guys - what voltage to set e6850? It is stock at 3.0 ghz, I would like to run at 3.2 on air - with OCZ Vendetta2. So in bios, what would be the best for that?
Thanks,
zilla
I build, I game, I upgrade. I build, I game, I upgrade. I build.....
Old December 5, 2008, 05:48 PM
If your going to overclock don't bother with just a small jump as you can do that without or shouldn't need to increase the voltage.
Go for like 3.5 or something
Old December 5, 2008, 09:56 PM
dadzilla's Avatar
OK - but maybe I better read the stickies or something, because I don't know how to get 3.2 without upping the voltage.
Old December 5, 2008, 10:47 PM
Dashock's Avatar
Dadzilla what Enaberif said is if your going to make a jump from 3.0 ghz to 3.2 ghz you will not need to increase the voltage up. Your processor should be able to handle that increase just fine.
If you plan to increase your voltage aim for 3.5ghz as that will probably need your to increase your voltage. I don't think you will see that much of improvement from 3.0ghz to 3.2 what is your temps right now you could probably run that Vendetta 2 if your temps are fine to 3.6 ghz.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old December 6, 2008, 04:05 AM
Chilly's Avatar
Agreed, and even to 3.6GHz should only require a small bump. If you don't want to increase it at all, 3.2GHz should be a breeze. Your OCZ Vendetta 2 should be great for anything upwards of 3.6GHz.
In other words, don't worry, have fun, enjoy your speed boost!
Old December 6, 2008, 09:19 AM
dadzilla's Avatar
OK so I am a rank noob at this - I get into bios with the delete key and just adjust the FSB a little?
Old December 6, 2008, 09:21 AM
sswilson's Avatar
Yep, that's the first step. :)
Small bump, test for stability, reboot, small bump, test for stability, reboot, small bump, etc.......
Old December 6, 2008, 09:53 AM
dadzilla's Avatar
Thanks to all - I did give it a bit of a try just now but I don't see the spot for FSB adjustment right away. MSI has this corny utility that lets me set to "Colonel" but it didn't change my game experience score at all! CPU temperature is 28 at the moment at idle, but I need a better software to monitor that. What do you guys use?
Old December 6, 2008, 10:05 AM
sswilson's Avatar
That's their "auto" overclock feature... don't bother with it.
I've got the manual for a P6N SLI here so if the bios features are similar you need to set the "System Clock Mode" to manual in order to enable FSB & Memory speed adjustments.
Use either Coretemp or Realtemp to monitor your CPU temps.
Old December 6, 2008, 10:19 AM
dadzilla's Avatar
Thanks sswilson - I have to do some family stuff for today but I will try that tonight or tomorrow and see how I do then. :)
