Use coretemp or Realtemp to check your load temps. If under 60-65, you can probably add some volts (up to a max of 1.4V) and push your OC a bit more.
Or, you can leave your OC alone, and try lowering your vCore. Lower a notch, run OCCT for 2 hours. If it passes, lower another notch.
Honestly though, you're at 4.0Ghz. That's a decent OC for that chip. What will 4.1 do for you? Unless you're doing Superpi or other benchmarks, you won't notice the difference.
