  #91 (permalink)
Old October 3, 2013, 04:42 PM
trodas's Avatar
46min 58.438sec sec
Opteron 148 2200MHz 200x11, 1.40Vcore CPU-Z Validator 3.1 (CPU-Z show the Vcore wrong, HWiNFO get it right)
1024MB Mushkin BH-6 Hi Performance 2.5-3-3-7
Sapphire "Grouper" A9RX480 (ATI RX480) View image: Sapphire A9 RX48 3 View image: Sapphire A9 RX48 2
30G Corsair Nova 2 SSD
Point of View 8600GT 256MB DDR3 540/1.4GHz
17" BenQ FP75G 1280x1024 75Hz VGA
Sony Optiarc AD-7621S
Using PS2 mouse (Logitech MX510 blue) with PS2 rate set to 200Hz.
Powered by Enermax Liberty 620W PSU
trodas`s SuperPi - 32M score: 46min 58sec 438ms with a Opteron 148 90nm
No overclocking yet, as this thing is pretty unstable ATM. I suspect rams (stable with one stick, not much stable with two, eg. the second one) and not recapped old PSU.
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
  #92 (permalink)
Old October 3, 2013, 05:50 PM
SuperPi 32m score: 7m 35.4s
CPU: Intel Ivy 3750k 4.5Ghz 1.232v
Memory: 2x4 Patriot Viper Green 800 MHz 8-9-9-20 1T 5 Latency 1.4v
Mobo: ASUS Gene V
Hard Drive: Samsung 540 240 GB
  #93 (permalink)
Old October 5, 2013, 03:51 AM
trodas's Avatar
Red face
TomBo - holly...
But wait! Now we can compare CPUs at the SAME frequency!
48 min 4.047 sec
Pentium 4 650 3400MHz (200x17) 1.375Vcore
2048MB OCZP4001G 2-3-2-7 200MHz 2.60V
MSI PM8M3-V (VIA P4M800)
500G Western Digital 16MB cache (WD5000AAKB)
PNY 6800GT 256MB DDR3 350MHz/1GHz
19" iiyama ProLite E1980SD 1280x1024 75Hz DVI
DVDRW NEC DV-4551A (16x DVDRW)
So, at 3400MHz clocks, the i5 need 7:35, while P4 need 48:04 ... that is 6,53x faster - or simply more effective per clock.
Absolutely minimum gain in SuperPi is somewhat typical for P4 - from Pentium 4 540 at 3.2GHz 1MB L2: 48.45.890 to 48.04.047 with Pentium 4 650 at 3.4GHz 2MB L2 :( Suxx!
Twice the L2 and 200MHz more for what? 41sec in 48min times?! WTF!
  #94 (permalink)
Old December 28, 2013, 05:12 AM
trodas's Avatar
Pushing clocks: AMD 939:
27min 12.437sec
Opteron 148 2750MHz 250x11, 1.425Vcore CPU-Z Validator 4.0
1024MB Kingston 2.5-3-3-7 @ 229MHz
Asus A8R32-MVP Deluxe (Radeon Xpress 3200)
trodas`s SuperPi - 32M score: 27min 12sec 437ms with a Opteron 148 90nm
  #95 (permalink)
Old January 20, 2014, 07:02 AM
trodas's Avatar
Wink
27min 15.031sec
Opteron 148 2805MHz 255x11, 1.425Vcore CPU-Z Validator 4.0
2048MB OCZ 2-3-2-7 @ 200MHz
trodas`s SuperPi - 32M score: 27min 15sec 31ms with a Opteron 148 90nm
  #96 (permalink)
Old February 8, 2014, 03:02 PM
trodas's Avatar
A little bit futher - AMD 939:
26min 38.844sec
2048MB OCZ OCZP4001G 2.5-3-3-7 @ 233MHz
trodas`s SuperPi - 32M score: 26min 38sec 844ms with a Opteron 148 90nm
(as seen, for SuperPi 1M I "get away" with TWR setting 2... for 32MB SuperPi I had to stick with 3)
  #97 (permalink)
Old July 20, 2014, 03:17 AM
trodas's Avatar
Wink
i5 750:
9:59.790min
i5 750 (210x18) 3788MHz, 1.280Vcore CPU-Z Validator 4.0
2x 2048MB DDR3 1600MHz G.Skill RipJaws 9-9-9-18 1.7V (F3-12800CL9D-4GBRL)
2x 2048MB DDR3 1600MHz Kingston HyperX 9-9-9-18 1.7V (KHX12800D3K2/4G)
MSI P55A-GD55 Intel P55 chipset socket 1156 mainboard rev. 2.1
trodas`s SuperPi - 32M score: 9min 59sec 790ms with a Core i5 750
  #98 (permalink)
Old October 1, 2015, 05:24 PM
trodas's Avatar
26:49.564min
Opteron 148 2797MHz 279x10, 1.40Vcore CPU-Z VALIDATOR
2048MB Qimonda (HYS64D128320HU-5-C) 3-3-2-8 2T @ 254MHz
Sapphire PI-A9RX480 (Radeon Xpress 3200)
Powered by eVGA 850W SuperNOVA G2 PSU
trodas`s SuperPi - 32M score: 26min 49sec 564ms with a Opteron 148 90nm
First attempt with Qimonda. I have to recap the board, because I swear it run at 1T happily, now it just did not run at 1T for rams, not even at stock clocks, witch is very very bad :(
