I haven't received my x58 platform upgrade yet but while it's en route, I've been reading around for some overclocking know-how. I'm just wondering if anyone here has any tricks or advice that they can share or comment on any of the things below that I've read.
Some things I've found (not all are verified) are:
- If you turn off HT, you can get slightly higher speeds and better performance in many applications that aren't optimized for it.
-the p6t has trouble with 20X200- try 19X>200 or 21X<200 if you're shooting for 4000 with your 920
-On the p6t, try using the orange slots first- the black ones sometimes won't allow post.
-turn off everything but multicore, turbo,
load line?? in your settings
-These things are hot- don't fret if your load temps are topping over 70
-be sure to stay under 1.65V for your memory
- a little overclock settings optimizer by gogar from XS
Gogar's Core i7 OC Optimizer
