  #51 (permalink)
Old December 21, 2008, 07:31 AM
Babrbarossa's Avatar
Some rpeliminary tweaking here- I used the Turbo mode to get the 21X multi, but the only way I could keep the turbo option open in the bios was to keep speedstep enabled, so there is a delay after I start up superpi before the multi bumps to 21- is this normal- maybe a bios update might change this. Seems like they don't want us burning out our CPUs so to get the real clocks we need to allow software throttling.
I also have a dual boot with my old 32bit vista disk, and when I boot into that, speedstep doesn't seem to be throttling back the multi- I got just over 10 seconds there, but the disk and registry are messy and there are alot of processes running.
i7 920 4.2 (H2O)
P6T Deluxe
3X2 patriot at 1600 9-9-9-23
64bit vista
  #52 (permalink)
Old December 21, 2008, 07:47 AM
Finch's Avatar
the core i7 are beating us down
i will remove them from the rankings.... joke
If you are an overclocker please come and participate to the HWC Benchmarks Competitions, look for the stickies.
  #53 (permalink)
Old December 21, 2008, 08:00 AM
3.0charlie's Avatar
Pretty good first run babs... as for the chip throttling, I know that load and temps are related - the board decides when the Turbo can kick in, but I still haven't found exactly when that is allowed.
Hydro-Quebec is salivating...
  #54 (permalink)
Old December 21, 2008, 01:41 PM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
Should I sweep in and post a crushing result?
  #55 (permalink)
Old December 21, 2008, 01:43 PM
Finch's Avatar
no...
  #56 (permalink)
Old December 21, 2008, 01:44 PM
3.0charlie's Avatar
Why not, it's called a competition after all...
  #57 (permalink)
Old December 21, 2008, 01:47 PM
Finch's Avatar
you may post only if it beats 3.0charlie score. if not then dont bother.
joke
  #58 (permalink)
Old December 21, 2008, 03:25 PM
MAC's Avatar
MAC MAC is offline
Ok, well I will start off slowly
9.563 secs.
i7 965 XE @ 4263MHz, 1.425V BIOS
ASUS Rampage II Extreme
G.Skill 3x2GB 1764Mhz 10-10-10
  #59 (permalink)
Old December 21, 2008, 03:32 PM
hausner's Avatar
Well not too much but still without tweaks and old xp with sp2
9.437s
E8600@4971mhz (1.48v)
Asus P5Q-Deluxe
4GB Mushkin Redline 497mhz 5-5-5-13
xp sp2
i7 6700K / Asus Z10L Pro Gaming/ Asus 1070 /Corsairs 16GB DDR4/ Samsung Pro SSDs/Enthoo Evolv mATX
  #60 (permalink)
Old December 21, 2008, 04:26 PM
3.0charlie's Avatar
Great numbers guys!
