  #141 (permalink)
Old February 26, 2009, 12:02 PM
Jake_HT's Avatar
http://jakeht.deviantart.com/
  #142 (permalink)
Old February 26, 2009, 03:26 PM
1Tanker's Avatar
Great times on these i7's, but generally, they can't beat an E8500 E0/E8600 on great air/water for 1M. 5GHz on water is easier to hit than an i7/4.4(unless serious water/phase) on an E8600.
  #143 (permalink)
Old February 26, 2009, 04:41 PM
"Quote This..."
That's because super pi is very poor at multi threading, it doesn't even bring one of my 4 cores past 35% load.
  #144 (permalink)
Old February 26, 2009, 04:43 PM
SuperPi has nothing to do with CPU calculations its all relevant to ram speed and fsb.
And socket 775 and ddr2 memory has MUCH higher capability for higher fsb and mem speed than i7 does.
  #145 (permalink)
Old February 26, 2009, 09:54 PM
"Quote This..."
Super PI is single threaded, so its relevance as a measure of performance in the current era of multi-core processors is diminishing quickly
The Gauss–Legendre algorithm used in super pi is memory intensive. But the triple channel ddr3 with integrated memory controller on the x-58 platform is easily triple the advantage of core 2/ddr2.
I got PM'ed your post enabirif, by another member who is tired of your misinformation and has also blocked you.
  #146 (permalink)
Old February 27, 2009, 08:03 AM
"Quote This..."
Here are some benchmarks of stock clocked i7 systems kicking the ass of an overclocked core2/ddr2 system.
http://benchmarkreviews.com/index.ph...1&limitstart=9
  #147 (permalink)
Old February 27, 2009, 01:05 PM
"Quote This..."
the current world record is from an i7 at 5.4ghz, beat out the old record set by an e8600@6.7ghz.
  #148 (permalink)
Old February 27, 2009, 01:18 PM
3oh6's Avatar
Hardware Canucks Reviewer
false and false.
32M SPi is heavily dependent on memory bandwidth...1M has next to nothing to do with it since 1M is all held primarily in the CPU cache. this is why 4MB C2D's were that much faster than 2MB C2D's and why i7 hauls C2D's ass out to the wood shed clock for clock.
now...your second comment is absolutely ridiculous and i won't even bother touching it. just re read it and try to justify your comment, it makes no sense at all. DDR2 higher frequency than DDR3...i7 has a FSB?
ding ding ding...we have a winner, someone who knows what they are discussing
  #149 (permalink)
Old February 27, 2009, 01:34 PM
1Tanker's Avatar
Originally Posted by 3oh6 View Post
false and false.
I know i7 beats Core2 at 1M..clock for clock. And yes, there are a some i7's that have clocked well into the 5's... but that takes phase or better, and 5-5.2GHz E8600's don't need phase/LN2... yet are good for 8.9-9.1 sec's. i7 will hit the 8's but not as easily. There are a lot more E8600's in the 8's than i7's(yes i know i7 is newer). That's my take on it anyway...do you think i'm that far off the mark?
  #150 (permalink)
Old February 27, 2009, 09:33 PM
"Quote This..."
I dunno, lets do some math.
5.4 i7 beats 6.7 e8600.
that's 22% better clock on the 8400
apply the same ratio and a 4.2ghz i7 will still beat a 5.2 ghz e8400.
that said, i'll bet you dollars to donuts that 4.2 i7s are more common than 5.2 8600's.
