  #91 (permalink)
Old January 11, 2009, 01:34 PM
1Tanker's Avatar
Not bad Hausner. You need some kickarse RAM, and you'll get into the 8's.
Like my Ballistix(although it's only a 2GB kit, not 4GB). 500+mhZ@4-4-4-X works good.
Have you tried lowering PL to 9 or 8?
  #92 (permalink)
Old January 11, 2009, 02:37 PM
hausner's Avatar
I have that Balistix 2GB and they can do 715mhz 5-5-5-15 or 600-4-4-4-12 but i cant change to PL 9 - restart.I need DFI mobo or special bios for rampage extreme to get better score.W/E waiting for UPS guy tommorow and my order from Ncix.com (920,3gb g.skill black,asus p6t-dlx).
i7 6700K / Asus Z10L Pro Gaming/ Asus 1070 /Corsairs 16GB DDR4/ Samsung Pro SSDs/Enthoo Evolv mATX
  #93 (permalink)
Old January 11, 2009, 03:55 PM
1Tanker's Avatar
Nice..member of the 1400MHz club. Best mine does is 666@5-5-5-15... but that's only on a GA P35-DS3L.
  #94 (permalink)
Old January 11, 2009, 04:08 PM
Finch's Avatar
nice! score is updated, but stop it hausner it has been your 3rd bench after saying that it is your last bench before you get a i7...
btw do you guys know where i can find a cheap phase change? or maybe some one on this forum is capable of building me one?
If you are an overclocker please come and participate to the HWC Benchmarks Competitions, look for the stickies.
  #95 (permalink)
Old January 15, 2009, 10:03 PM
derrXIII's Avatar
Super PI - 13.232
CPU - Q6600 @ 4001.5 Mhz
RAM - G.Skill F2 PC2-8000 / 5-5-5-15 @ 444.7
MOBO - Biostar i45 / P45
= in top five for 65nm?
Q6600 @ 3.6GHz (400x9) | Biostar i45 | 4850 (700/2010) | G.Skill F2 PC2-8000 @ 800Mhz 2x2GB
  #96 (permalink)
Old January 16, 2009, 06:26 AM
SuperPi: 18.127 seconds
CPU: AMD Phenom II 940 @ 3.876Ghz
RAM: Muskin Redlines PC-8000 @ 544Mhz 5-5-5-18-T2
Motherboard: Gigabyte GA-MA790GP-DS4H, F3h BIOS
AMD Phenom II 940 @ 3.0Ghz | OCZ Vendetta II | Gigabyte GA-MA790GP-DS4H 790GX/SB750 | 2x2gig Musking Redlines 5-5-5-18-24 T2 | XFX 8800GT XT 512MB @ 702/1023 | WD Raptor 36,74gig | OCZ GameXtreme 850w | Cooler Master Cosmos 1000 | Samsung Syncmaster 2443BW | Logitec x530 5.1 | Windows 7 Home Pre.64-bit
  #97 (permalink)
Old January 16, 2009, 07:19 PM
derrXIII's Avatar
EDIT!
Super PI Score - 12.656
CPU - Q6600 @ 4010.6 Mhz
RAM - G.Skill F2 PC2-8000 / 5-5-5-15-T2 @ 445.6
  #98 (permalink)
Old January 19, 2009, 02:10 AM
9.157s
Vista ultimate.
4.495ghz
I wonder how much time I will be able to shave off if I use a lighter operating system.
Matching you exactly MAC. A bit less efficient since I am clocked a bit faster on my lowly 920, but might try to bench on xp to get better numbers.
  #99 (permalink)
Old January 19, 2009, 03:22 PM
Finch's Avatar
to DerrXIII and CntdwnToExtn, for some reason i cannot see the attached pics that you guys posted...
for the rest it has been updated.
BTW it is even between MAC and sheepdogexpress at 9.157s
  #100 (permalink)
Old January 19, 2009, 06:11 PM
Killswitch's Avatar
Ok, you can update my score in the AMD 940 ranks.
23.649s
AMD Phenom 9950 @ 3300MHz
G.Skill F2-6400CL5-1GBNQ @ 440MHz 4-4-4-12
Asus M3A79-T
Thermaltake Prowater 850i
Thanks Finch.
