  #51 (permalink)
Old March 10, 2007, 11:35 AM
Level up: 75% Level up: 75% Level up: 75%
Level: 8 - 46 points to level up
here's mine
  #52 (permalink)
Old March 10, 2007, 01:28 PM
sswilson's Avatar
Super Moderator
That's a really sweet OC on a sempron. Is the AM2 vers. stock @ 1.8?
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
  #53 (permalink)
Old March 10, 2007, 01:57 PM
stock was 1.6, and yeah, am2
  #54 (permalink)
Old March 10, 2007, 02:19 PM
sswilson's Avatar
Super Moderator
Well.... don't make me ask about each individual component.... how's about a sig? :)
  #55 (permalink)
Old March 10, 2007, 02:23 PM
you'll get each component.
biostar t-force am2 micro atx mobo.
sempron 2800+ ran it at 2.6 most of the time
400w fortron psu
either the onboard or a 7300le for video
2gb's G. Skill HZ, about 550mhz 5-5-5-15, 2v (i forget, but thats close)
water cooling:
DD RBX, and a bonnie heatercore rad with 2 80mm fans and no shroud
thats about what it was
  #56 (permalink)
Old March 10, 2007, 02:27 PM
sswilson's Avatar
Super Moderator
How's the biostar for OC'ing in bios?
I've never run one and always thought they were comparable to Asrocks.
  #57 (permalink)
Old March 10, 2007, 02:31 PM
meh, its sorta ok. it made it to ~355 htt, but thats with fiddling with it. only has 1.55 (real) volts to cpu, and 2.17 for ram. no setting for 1T or 2T. wouldn't for the longest time boot past 280 htt with ram set to 400(bios update fixed it though). but you get what you pay for i guess. and it was like $75 new.
  #58 (permalink)
Old March 10, 2007, 02:55 PM
sswilson's Avatar
Super Moderator
Heh... sounds exactly like the S754 6100 chipset Asrock I'm running on my daughter's computer.
Can't complain though, it was one of the few onboard 6100's that allowed any OC at all, and there's a voltage mod for upping the available VID if I decide I want more. :)
  #59 (permalink)
Old May 10, 2007, 10:19 AM
Babrbarossa's Avatar
Super Moderator
Might as well update the other benches while I'm at it- this was done at 3.8GHz, RAM: 4-5-4-10 @ 1:1 ddr2 900
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
  #60 (permalink)
Old May 10, 2007, 12:22 PM
CMetaphor's Avatar
Level up: 60% Level up: 60% Level up: 60%
Level: 15 - 261 points to level up
Oooooooh, Im sooooo into this competiton once my system is built. I'll probably start on it tonight, have some benchs up with the stock speeds by the weekend (I take my time building dammit, I loooooove wiring everything nice, hehe)
Current System: "Gale Force" (09-28-2008)
AMD X2 6000+ w/ TRUE (2x Scythe 120mm) | Asus Crosshair MB | 4Gb OCZ Plat.Rev.2 PC-6400 RAM w/ Corsair Memory Cooler | VisionTek 4870X2 2gig| Coolermaster CM Stacker 832 w/ 7x 120mm Fans (2x Tricool, 5x CM), 1x 80mm CM, and 1x Antec "Big Boy" 200mm Tricool Fan | Silverstone Strider 1Kw PSU | Seagate Barracuda 7200.11 500gig x 4 (Raid 1 & Raid 0)| 3x BenQ FP222w 22' Wide 5ms LCD Monitor & Matrox Triplhead2Go DE
Next system? Who knows...
9800gx2 Official Leaks At Cebit08!! vertex112 Press Releases & Tech News 13 March 10, 2008 07:13 PM
It's Official: Bungie Leaves Microsoft SKYMTL Press Releases & Tech News 5 October 8, 2007 04:47 AM
163.44 BETA official (from nvidia) Gamashinoch Video Cards 8 August 22, 2007 07:25 AM
early K10 sandra test Shadowed Rumor Mill 8 May 2, 2007 12:53 PM
Official Sandra CPU Multi-Media Top 15 Supergrover Overclocking, Tweaking and Benchmarking 13 March 11, 2007 11:30 PM
