  #31 (permalink)
Old February 24, 2007, 09:59 AM
DerekOldschool's Avatar
Originally Posted by sswilson View Post
That's a pretty sweet OC on that opteron.
What are your idle/load temps?
Thanks - I would have liked to get a stepping that does 3Ghz. Then I could really get the most out of this ram.
Temps:
~50-52C load
~25-27C idle
thats right now when its only 19C in my computer room. In summer it can reach 28C in here and I have to drop everything to ~2.2Ghz
i7-860 @ 4.2Ghz (1.33v) • EVGA P55 FTW SLI (E657-A51 Bios) • Thermalright ULTRA-120 Trueblack Rev.C • G.Skill Ripjaws 4G DDR3-2000 • Antec 850W TPQ • 2xBFG GTX280 1G SLI • Acer X263W 25.5" LCD • Crucial C4 256G • WD FAEX 1TB • LG DVDRAM GH20NS10 • Thermaltake Kandalf case • Windows 7 Pro x64
E8400 @ 3.96Ghz (1.42v) • EVGA 780i A1 (P08) • ZalmanCNPS9700NT • G.Skill 4G DDR2-1000 • eVGA GTX280SC 1G • Windows 7 Pro x64 • 1xSeagate Barracuda 7200.11 500G
  #32 (permalink)
Old February 25, 2007, 05:58 AM
BALISTX's Avatar
Here are my results.
Dhrystone ALU - 6825 - AthlonXP@2.16GHz
Whetstone FPU - 3467 - AthlonXP@2.16GHz
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
  #33 (permalink)
Old February 25, 2007, 09:26 AM
Supergrover's Avatar
Sorry missed this
Updated
R.I.P.
  #34 (permalink)
Old February 25, 2007, 04:11 PM
Hey Supergrover,
You missed my Sandra post - its near the end of page 3
Thanks
  #35 (permalink)
Old February 25, 2007, 04:12 PM
sswilson's Avatar
Temps:
~50-52C load
~25-27C idle
Yeah, 3G on a 165 is the "holy grail", but honestly you can't complain about a 1.8G chip that OC's to 2.7.
Was that the max it looked like it would do, or did you back off a bit because of temps? (I had my 3700 up to 2900 on air, but I was getting low - mid 50's on load and waited until I got WC before pushing it any further).
  #36 (permalink)
Old February 25, 2007, 06:22 PM
Hey Supergrover,
Thanks
Damn okay just popped in before dinner, I'll get it tonight.
You can always hit me with a PM if I miss something I dont mind in the least.
R.I.P.
  #37 (permalink)
Old February 25, 2007, 07:55 PM
Updated
You can change the amount of posts per page bro.
Babrb dont do this, it'll kill you on dail-up
R.I.P.
  #38 (permalink)
Old February 26, 2007, 04:25 PM
thanks SG,
I would have PM'd you, but I figured it wasn't that important - I just didn't want you to miss it altogether.
@K1ller_Instinct: If you could get your hands on a XP mobile cpu, you'd have an unlocked multiplier and you'd be able to run it at 2400 or 2500Mhz depending on the rest of your set up - which looks good BTW (Check out my Socket A rig - Blackmamba - in my sig)
@sswilson: my cpu just isn't stable past 2.8Ghz - also, the temps get up into the mid fifties if I up the voltage a bit. I personally don't think spending the extra $$$ on a WC kit would be worth it for me. From what I have read about this stepping, 2.8Ghz is the max. But I ain't complaining! a %53 overclock is nothing to squak about
  #39 (permalink)
Old February 26, 2007, 06:34 PM
Deathspawner's Avatar
Don't include me if this is an unfair entry.
58577/40586.. CPU was about 80C when stressed. Stressing for over an hour will result in 90C+ temps though, but still retains perfect stability.
Techgage.com | Editor in Chief
Intel Core 2 Quad Q9450 @ 3.20GHz, ASUS P5K Premium WiFi-AP, OCZ 8GB PC2-6400, EVGA GTX 285 1024MB
Seagate 500GB, 750GB & 1TB, Pioneer 22x ODD, Corsair 1000HX, Thermalright Ultra-120, CM Storm Sniper
Dell 2408WFP 24", ASUS Xonar Essence STX, Ultrasone PRO 750, Gentoo Linux (KDE 4.4, 2.6.32 Kernel)
"Take care to get what you like, or you will be forced to like what you get!" - H.P. Baxxter
Profiles: Last.fm | Xbox Live | Steam
  #40 (permalink)
Old February 26, 2007, 07:29 PM
BALISTX's Avatar
DerekOldSchool - I'm just wondering if my cpu is unlocked already. I don't want to really mess with it cause the motherboard was designed for HP so God knows what proprietary **** they have done with the BIOS.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
9800gx2 Official Leaks At Cebit08!! vertex112 Press Releases & Tech News 13 March 10, 2008 06:13 PM
It's Official: Bungie Leaves Microsoft SKYMTL Press Releases & Tech News 5 October 8, 2007 03:47 AM
163.44 BETA official (from nvidia) Gamashinoch Video Cards 8 August 22, 2007 06:25 AM
early K10 sandra test Shadowed Rumor Mill 8 May 2, 2007 11:53 AM
Official Sandra CPU Multi-Media Top 15 Supergrover Overclocking, Tweaking and Benchmarking 13 March 11, 2007 10:30 PM
