<~----> WTF is going on with my 8400 - Hardware Canucks
Old November 24, 2008, 01:53 PM
Default WTF is going on with my 8400
So I folowed the instructions you all gave me to get my e8400 to 3.6GHZ but when I look at cpuz one minute it shows the right speed (3.6 and 9X multiplier) the next it shows 2.4ghz @6X what is going on here and how do i corect it? (two pictures of my CPUZ are attached):help:
Old November 24, 2008, 01:55 PM
"Quote This..."
Thats is speed step. It clocks down your multiplier when you are not under heavy useage. Leave it on, I do.
Old November 24, 2008, 01:56 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Find C1E and/or EIST options in the BIOS and disable them. Basically your CPU is throttling down when idle to save energy.
Old November 24, 2008, 01:57 PM
"Quote This..."
also, dude what is up with the title of this thread. Makes zero sense. Try and be a bit more legible please.
oh ok I thought I broke someting *wipes swet from brow*
Should I leave it on as Squeetard sugested or what?
"Quote This..."
Why disable it? It's a good thing.
Old November 24, 2008, 01:59 PM
Ok my bad making up thead titles ant my strong sute by any means
Old November 24, 2008, 02:02 PM
"Quote This..."
Thank you man. You'll get more replies too.
Old November 24, 2008, 02:03 PM
Seriously this is a common thing thats been asked about 100,000x and if you had clicked the search either on here or the ncix forum or even google you'd have a answer in 2 seconds.
Also I agree please choose better thread titles as they make you look like bad.
Old November 24, 2008, 02:12 PM
Ok one last think how do these teps look to you?
