<~----> WTF is going on with my 8400 - Page 3 - Hardware Canucks
  #21 (permalink)
Old December 6, 2008, 04:46 AM
BALISTX's Avatar
Depends on the CPU. An E8400 shouldn't but if you have an E2xxx or an E5xxx series it might need that much.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
  #22 (permalink)
Old December 6, 2008, 06:03 AM
sswilson's Avatar
Originally Posted by Gameplaywarrior View Post
After some tweaking I got the voltage down to 1.3V respectfully as it varies with speed step. Thanks to my new heat sink which came friday (thay left it at my store as aposed to my house) It idles at 20C now and load is 43C. I am sooo pleased with the results now what do you all think?
What's your room temperature? The sensors on my DFI board report (at best guess) at least 10c under actual temps so you might want to take the temps you're seeing with a grain of salt.
Not a big deal with the kind of temps you're seeing now, but something to think about if you push the OC to a point where you are seeing temps at the upper end of what is considered safe.
