Old November 24, 2008, 05:12 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Look fine
Old November 24, 2008, 08:05 PM
Snafu's Avatar
Are those temps at idle or under load? If they are idle temps then they look high particularly with a decent cooler. For load they are good. What are the difference in temps from idle to load on the two cores?
Newest system: Intel E8400, Gigabyte EP35-DS3P, OCZ PC2-9200 Reapers, Seagate 3GB/s HDD, etc.
Others are kicking around the house.
Old November 24, 2008, 08:50 PM
Eagle Eye's Avatar
Gameplay what heatsink are you currently using to cool your cpu?
Are you putting any additional voltage into your E8400?
Old November 29, 2008, 02:17 PM
Well I curently have an artic cooler 7pro but I have an OCZ Vendetta on order to arive on monday or tuesday. I am putting about 1.272V to it (acoring to CPU-Z)
Temps are not under load
Old November 29, 2008, 03:59 PM
Moneyless's Avatar
For idle temps mid-40s is pretty high, good thing you've ordered that Vendetta 2 'cause it will do a much much better job then that Freezer 7 Pro. :)
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
Old November 29, 2008, 04:41 PM
Snafu's Avatar
Yeah mid-40's is high especially with an aftermarket cooler. What are the load temps like? There's been talk about sensors sticking so I wonder if your load temps are similar to idle temps (indicating stuck sensors). I have one that might be stuck and plan to update teh bios and see if maybe it is just a board issue.
Although I have seen better results with other coolers, the HDT coolers aren't too bad.
Old November 29, 2008, 05:09 PM
After some tweaking I got the voltage down to 1.3V respectfully as it varies with speed step. Thanks to my new heat sink which came friday (thay left it at my store as aposed to my house) It idles at 20C now and load is 43C. I am sooo pleased with the results now what do you all think?
Old November 29, 2008, 05:43 PM
Snafu's Avatar
Both cores running at those temps? That's good (presuming RT is ~20C)
  #19 (permalink)
Old November 30, 2008, 12:17 AM
well it was but the voltage is stable for only about 2hrs so I will have to bump it up some tomorw
  #20 (permalink)
Old December 6, 2008, 05:26 AM
from my experience, the CPU shouldn't need 1.3v to reach 3.6GHz stable.
