  #21 (permalink)
Old November 12, 2008, 06:44 PM
SugarJ's Avatar
Yes, now that it seems stable the next step would be to reduce voltages slightly and try again. This brings back memories for me, I loved my P35-DS3L.
  #22 (permalink)
Old November 13, 2008, 08:19 AM
Well I tried everyones advice and stepped it back down a few times. My last step was two positions below 1.35v I forget what the exact number is but I ran it while I slept and it stayed stable for the 8 hours on the Prime 95 blend test. Highest temps I hit was 60 on each core which is 4 degrees lower for core 1 and idle temps were 35 this time vice 40:) The volts under stress were showing up as 1.264v.
Now I just have to figure out what to do with my new Redline 2x2gb ram set that should be arriving today. I love this site, that deal on the redlines was amazing!
  #23 (permalink)
Old November 13, 2008, 05:25 PM
Ok I poped in my new 2x2gb redlines and had to make a few adjustments. Now that I am running 4ghz stable with 1.3125v and a max temp under stress of 56c what else can I do? Would overclocking the RAM help much or would I be best for overclocking the GPU next. This is mainly just for playing games, I do not use the computer for anything else.
  #24 (permalink)
Old November 13, 2008, 05:48 PM
SugarJ's Avatar
Are you running at 890mhz right now? 2.0 multiplier? You could try 2.4 multi to run at 1068mhz or you can try using memset and seeing how low you can get your timings while running at 890.
For example, my 5-5-5-15 DDR2-1000 memory runs at 4-4-4-10 at DDR2-860.
  #25 (permalink)
Old November 13, 2008, 11:52 PM
Right now CPU-z is saying I have
DRAM freq 534.mhz
FSB:DRAM 5:6
CAS Latency 5
RAS# to CAS# delay 5
RAS # Precharge 5
cycle time 15
Command Rate 2T
  #26 (permalink)
Old November 14, 2008, 12:01 AM
1Tanker's Avatar
DRAM freq 534.mhz
FSB:DRAM 5:6
CAS Latency 5
RAS # Precharge 5
cycle time 15
Command Rate 2T
Good job Mishtar. 1.3125v for 4GHz is a pretty good result, on C0 stepping.
  #27 (permalink)
Old November 14, 2008, 08:50 AM
Thank you:) I am going to try the video card next. I tried to use ATItool but Vista 64 will not let me so I will try ntune for now. Once I get something stable in Ntune I think I will try it in the video cards bios!
  #28 (permalink)
Old November 14, 2008, 12:24 PM
rjbarker's Avatar
Great job on that CPU OC...wow...great Voltage for 4...I'm jealous!!
As for nTune and OC'ing GPU,,,don't bother with it..its brutal and very problematic...for simple GPU OC'ing I recommend Precision 1.3.3...
Firestrike Extreme: 21.452
MARK 11: 32.530
