You can score high and get points just don't expect to knock Hipro down off the top of the charts today. Remember, scoring is based on averages, so anytime you do better than the average OCer you have something to score with. It's just that every guy who hits 4GHz on a C2D thinks it's a wild OC... but it's really not. HWBOT pretty much shows you where things stand. If your score falls well short of what other people are doing with an equivalent cooling method, then you have something to shoot for in improving your rig. Learning to bench and what makes a particular benchmark fly is half the challenge. Example, I think the top A64 x2 Spi score for a 5000 BE is mid 25s.. Without a tweaked OS, I score low 26s. So how would I fix that? Easy, I load a stripped version of WIN2K and turn off the vast majority of the services just leaving it bootable basically. I crank up the MHz on my chip and allocate the Spi process to the core that I've already determined is least likely to crash at the higher frequency. I run Spi three times in a row capturing my validation each time. I knock 3/4 seconds off my Spi time, take 1st 2nd or 3rd in my weight class and score points. I score without the fastest chip or cooling just because I know how to make the bench sing a little (not like those Japanese teams though). Using the same process for 3Dmark you might run it 500 times before you know what makes it work best. Just beat the averages and you and the team start to score. It's a sport :) |
| Quote:
| Quote:
__________________ CSE: Corsair Obsidian 800D MOB: DFI Lanparty JR CPU: Intel C2Q 9550 @ 3.0ghz RAM: 4gb G.Skill Pi PC2-8800 GPU: XFX 8800 GT Alpha Dog Edition PSU: PC P&P 750w (Original) Heatware: My Heatware |
I've done all I could today, winning 10.3 pts using my laptop. Managed to snag a few awards too. But forget using my Quads - I don't have the exotic cooling, and the board vmods to raise their FSBs and play with the boys.
__________________ Main: X8DAi - 5520 - 5520 - Falcon SSD - Patriot 12Gb 1333 - lp 9800GT - WC'ed - Silencer 910W - RPC-270 HTPC: M3A78-EM - 920BE - 'cuda 1Tb - Gskill 4Gb 6400 - 3870X2 - SI-128 - Prelude - HX520W - Moneual 932B Fold: RIIG - 920 - Kingston SSD - Gskill 6gb 1600 - X300SE - WC'ed - Silverstone ST75F - Caseless, Headless |
Wow 3.0...you found a niche. That is the trick if you are not into extreme overclocking. Find yourself a niche like 3.0 did with his laptop's E2300 processor and start belting out those points since there are so few other people benching that type of hardware. |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hardware Canucks team Stats links | sswilson | HardwareCanucks F@H Team | 0 | May 20, 2007 01:06 AM |
| Linking to Hardware Canucks | BALISTX | Suggestions & Feedback | 7 | March 24, 2007 02:05 PM |
