  #46 (permalink)
Old February 6, 2008, 08:23 AM
Level up: 62% Level up: 62% Level up: 62%
Level: 27 - 874 points to level up
Bah! So unless you hit the average you don't get points? Thats pretty dumb.
If the expect anyone to want to submit a score for some points for a team then they are gonna have to take into account everyone otherwise whats the point?
CSE: Corsair Obsidian 800D
MOB: DFI Lanparty JR
CPU: Intel C2Q 9550 @ 3.0ghz
RAM: 4gb G.Skill Pi PC2-8800
GPU: XFX 8800 GT Alpha Dog Edition
PSU: PC P&P 750w (Original)
Heatware: My Heatware
  #47 (permalink)
Old February 6, 2008, 08:25 AM
Ugly n Grey's Avatar
The point is HWBOT is a metering tool for extreme overclocking and benchmarking. It's a sport unto itself and you have to beat the norm to score. It's a good place to look at too just to see if your rig is performing par or sub par compared to others.
  #48 (permalink)
Old February 6, 2008, 08:31 AM
3.0charlie's Avatar
Level up: 77% Level up: 77% Level up: 77%
Level: 28 - 586 points to level up
You need more than an average oc to have points: you need to have an oc higher than 4861MHz for 0.2 point.
hwbot.org - Top Results.
Main: X8DAi - 5520 - 5520 - Falcon SSD - Patriot 12Gb 1333 - lp 9800GT - WC'ed - Silencer 910W - RPC-270
HTPC: M3A78-EM - 920BE - 'cuda 1Tb - Gskill 4Gb 6400 - 3870X2 - SI-128 - Prelude - HX520W - Moneual 932B
Fold: RIIG - 920 - Kingston SSD - Gskill 6gb 1600 - X300SE - WC'ed - Silverstone ST75F - Caseless, Headless
  #49 (permalink)
Old February 6, 2008, 09:01 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Heh, no one said it is easy. Run some wprime, you can usually pick up points fairly easily with that bench. :)
  #50 (permalink)
Old February 6, 2008, 02:04 PM
Wankerfx's Avatar
Level up: 60% Level up: 60% Level up: 60%
Level: 16 - 293 points to level up
Hmmmm, it seems that my stickied thread is no longer stuck, and has disappeared off the face of the Earth.
[ER]
  #51 (permalink)
Old February 6, 2008, 02:47 PM
Cptn Vortex's Avatar
Level up: 51% Level up: 51% Level up: 51%
Level: 24 - 811 points to level up
Aw, they didn't give me any points for my verified Athlon XP 2000+ stock system....booo urns!
The Vortex H20
DFI X38 LT
Xeon X3210 @ 3.2GHZ 1.30V
PNY 9800GX2 (750/2200)
4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V
Ultra X3 1000W PSU
Auzentech X-fi Prelude
2x500GB Hitachi RAID 0, 250 Seagate
Sharp 32" Aquos 1080p
Benq W500 1080i Pojector.
Watercooling:
D-Tek Fuzion Bowed, MCR320+Gelid Silent 12 Fans, MCP655w/EK top, EK Multioption 100ml Res, DD 9800GX2 block, MCW30, MCR320+Gelid Silent 12 fans.
  #52 (permalink)
Old February 6, 2008, 02:53 PM
Exactly! hahah we should get points for everything!
Seems that site is a site for bragging rights... I'm honestly quite disappointed I didn't get any points.
  #53 (permalink)
Eldonko's Avatar
Make sure you put the CPU/GPU in your submissions properly. Start to type the CPU/GPU and a drop down menu will appear. Then select it from that otherwise it wont work. I saw your submissions say unknown CPU and such.
If you did it right my bad, just trying to help. :)
  #54 (permalink)
Old February 6, 2008, 03:15 PM
BALISTX's Avatar
Level up: 96% Level up: 96% Level up: 96%
Level: 21 - 55 points to level up
WOOT!! I got an award
#1 Turion 64 MK-36 in SisoftSandra with 7180 fpu
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
  #55 (permalink)
Old February 6, 2008, 03:19 PM
3.0charlie's Avatar
hmm. Unless you have some older hardware, or some less used hardware, I see no point in trying to compete. Look at most (if not all) top 20s: all are cooled either by LN2, dice, SS, cascades.
Sorry guys, I'm out.
  #56 (permalink)
Old February 6, 2008, 03:29 PM
Wankerfx's Avatar
Thanks Eldonko, I fixed them.
[ER]
  #57 (permalink)
Old February 6, 2008, 03:33 PM
BALISTX's Avatar
Wankerfx where did you go to get that hwbot banner?
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
  #58 (permalink)
Old February 6, 2008, 03:42 PM
Wankerfx's Avatar
Once logged in, go to "options", then "signature" and you'll find two different links. Put one of them in your signature on the forums and it will appear.
[ER]
  #59 (permalink)
SKYMTL's Avatar
HardwareCanuck Review Editor
Ummm.....you can still get points without getting into the top 20. Just look at me, I got points for being 349th....
  #60 (permalink)
Old February 6, 2008, 03:49 PM
I'm 700th and didn't get any points.
Its a very big guessing game. I know its all in good fun but hey I'd like some points to and I share the same thoughts as 3.0 ..
Hardware Canucks team Stats links sswilson HardwareCanucks F@H Team 0 May 20, 2007 12:06 AM
Linking to Hardware Canucks BALISTX Suggestions & Feedback 7 March 24, 2007 01:05 PM
