  #31 (permalink)
Old December 11, 2008, 08:32 PM
mattlef's Avatar
man, all on stock volts? I'm gonna have fun with this chip.
if 3.3 is good on stock volts, then I'm sure 3.6-3.7 wont be that hard to obtain... if I dont hit a wall when it comes to temps.... hopefully my TRUE holds strong on this Quad.
CC-HotSpot Host
YouTube Instagram Twitter
  #32 (permalink)
Old December 11, 2008, 08:57 PM
BrainEater's Avatar
Oh yea.
A 20% OC is a gimmie on the core2 chips......my e6600 and my q9450 do it instantly.
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
  #33 (permalink)
Old December 11, 2008, 09:07 PM
mattlef's Avatar
I wonder if you can get to 4.0 on air?
CC-HotSpot Host
  #34 (permalink)
Old December 12, 2008, 07:32 AM
DK2 DK2 is offline
Mine so far, from 2.83GHz stock;
3.2GHz, its been running now 24/7 for 3 weeks okay.
3.4GHz, ran 4 or 5 days, but has crashed everytime when playing movies.
3.6GHz, ran a few hours to 1/2 a day, just random crashes.
I suppose I could tweak it some more, but I'm a little afraid to bump the
voltage too much on what is an everyday machine that I use for everything I do.
  #35 (permalink)
Old December 12, 2008, 09:33 AM
Lithotech's Avatar
...on what is an everyday machine that I use for everything I do.
If you use the machine for everything and have no backup system or archive of the OS, you should be more conservative of your clock. I'd say 3.2GHz is fine for that, especially if you are running stock voltages. Also, be sure you have all the power saving features disabled.
You could try right inbetween 3.2 and 3.4... like 3.33GHz. Basically, a 1333FSB (333MHz) at a 10X multi, but you only have an 8.5 multi? That'd be 392MHz x 8.5! 417MHz x 8x would also work.
How much voltage boost are you running? That chip should be OK at 3.4-3.6, with a minor to moderate vcore boost -- especially in that mobo. Check to see if you are running the latest BIOS update for that mobo too.
You have to determine if the instability is RAM, CPU, or NB related. You can do that by running Orthos or Prime95 in blend mode, and it should fail within 8 - 12 hours. Then run it in Small FFTs mode, if it still fails, then it is CPU volts or NB volts. If it passes, then it is RAM related and you should either up the Vdimm, increase the timings, or use a lower ram divider.
eVGA 680i SLI (A1) P31
Intel Q6700 Kentsfield | Scythe Ninja-B | Antec Tri-Cool 80cfm
4GB (4x1024MB) Corsair Dominator 8500
boot: 4x WD Caviar SE16 250gb SATA2 Raid-0
backup: Seagate 500gb 32mb SATA2
eye: eVGA 9800GTX+ SC 512mb 770/2.25ghz
candy: Samsung 940B-HAS | X-Fi XMusic | Pioneer DVR-212D SATA
juice: PC Power & Cooling 750Quad | Cooler Master HAF932
steering: Logitech G15 & G5 | E3D Pro/Momo Wheel | X-530's
  #36 (permalink)
Old December 12, 2008, 12:02 PM
DK2 DK2 is offline
Thanks.
From memory I think I set vcore to 1.35 (+.1) and added .2 to fsb and the memory controller, and upíd the RAM to 1.9.
The ram is rated for 1600 anyways so I am actually under clocking it.
Just using memtest86 I can seemingly run 3.4 no problem.
Temps are no problem, nothing goes above 50C loaded, case ambient is 30C.
maybe the video gets higher but I havenít bothered to check.
Besides my crashing hasnít been loading related anyways.
The crashing with movies is a hint I think which relates to the use of extended
Multi-Media instructions in the CPU (MMX), which I donít have a specific test for yet.
(trust me if I wasnít so busy Iíd love to prove that)
Otherwise Iíd blame the NB / FSB, I do have a temp sensor attached to the NB heatsink fins but its never gone above 40C.
But your right it is a everyday/everything use machine so I shouldnít push too hard.
I just thought somebody might use it as a refenence here, but maybe one of these weekends I'll fiddle with it again.
  #37 (permalink)
Old December 13, 2008, 06:22 AM
Lithotech's Avatar
Ahhh, K. Not the ram, although you can't be certain because the cpu/fsb speed and current mem divider maybe just not play well together. Also, many C2D boards have a FSB hole that simply refuse to work at certain speeds -- go beyond the FSB hole speed and it's OK.
Passing memtest is no garuntee it is stable. Only that errors in memtest is pretty much certain that Windows will be unbootable or unstable. Prime95 or Orthos is the best way to test stability within the OS.
Nevertheless, it does seem CPU related, and 1.35 vcore is quite mild. Give her 1.4V for a session and see if that clears up the crashing. Your cooler and temps are fine, another .5V won't be a problem at all. I run my E6750 at 1.45 - 1.5V to reach 3.8GHz on air, and CPU temps just start passing 60C load. That is pushing it for me, because like you this is my main work system, so that is kind of a suicide run for me.
Thanks.
  #38 (permalink)
Old December 15, 2008, 01:23 PM
probationer's Avatar
Currently running Q9550 @ 3.825Ghz still undergoing stress testing using P95 small ftt's so far 10 hours all good.
CPU-Z Validator 3.0
Will add voltages + screenshot when i get home from work.
I'm hoping to push it over the 4Ghz mark.
18 hours complete
Peak temps 57-57-53-53 from RealTemp mainly due to my room being closed off all day but meh well within safe limits .
  #39 (permalink)
Old December 16, 2008, 01:57 AM
Holy 1.52 vCore?
That's really high for 3825 MHz...i highly doubt it needs that much, though wow, you have nice temps compared to what you'd have with air.
Just an FYI, you need to run Large/Blend for FSB stability checking.
Small FFTs really doesn't stress that; just the CPU.
You'll likely need to start messing with GTLs to get much above 450 FSB, otherwise no amount of voltage helps after a point.
For me, as soon as i hit around 440-445 FSB i pretty much had to manually set GTLs, or i couldn't get Blend/Large stable.
Gigabyte X58A-UD3R | i7 930 | Corsair H50
G.Skill RipJaws 4x2 GB DDR3 | HIS Radeon HD 5870
3x Intel X25-M 80 GB RAID-0; OCZ Agility 120 GB | Samsung SH-S243D
Corsair HX1000 | Dell 3007WFP & Samsung 204T | 7 Ultimate x64
  #40 (permalink)
Old December 16, 2008, 09:59 AM
DK2 DK2 is offline
ya, Q9950 datasheet lists a Max of 1.45V core, but your temps are really good. What cooler?
anyways, I don't have the courage for going above spec. Depends how loose Intel is in posting their numbers thou.
good luck.
