Old May 5, 2007, 01:12 AM
Trial Member
Default Frustration OCing Pentium D 930
Hey all,
I have a Pentium D 930 (3.0/800) running on a Gigabyte 965p-DQ6 (rev. 1.0)
with 2x1GB sticks of Corsair DDR2-800. I am currently running an overclock of 4.0Ghz @1068FSB with my ram clocked at ~889Mhz @ 5-5-5-12. This is done by setting a 267MHz FSB with a 3.33 divider.
I have currently hit a wall, I can get it past that using the Gigabyte software based OC utility, and by setting it in the BIOS. However, if trying to do a cold boot, the system will fail and I have to wait for the machine to reset to defaults or do it myself. I know people have pushed these chips harder and am looking for any suggestions on things to try to get it higher, I've tried these with no effect:
Bumping Vcore to 1.4v
Northbridge/southbridge by 0.30V
Vmem up to 2.1V
Setting mem divider down to 2.0
Setting timings to auto
Setting timings manually to 6-6-6-20 (stock=5-5-5-12)
The best I can do is 272 performing a cold boot. The CPU multi is locked at 15. The board should be able to handle well past 267.
Any suggestions?
Old May 5, 2007, 06:04 AM
Babrbarossa's Avatar
Hi! Welcome to the forum- what kind of cooling and power supply do you have- and what are your temps like?
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
OCing help please SpateD Overclocking, Tweaking and Benchmarking 4 January 23, 2008 09:38 AM
WTB: 939 OCing Mobo superdude101 Buy/Sell & Trade 1 December 28, 2007 09:57 AM
Good 939 Cooler for OCing BALISTX Water Cooling 5 August 6, 2007 08:43 PM
Pentium Lives!! Pentium E2160 and Pentium E2140 Babrbarossa CPU's and Motherboards 4 June 4, 2007 05:25 AM
A64 ocing questions Jim Overclocking, Tweaking and Benchmarking 62 April 7, 2007 04:56 PM
