Old November 1, 2008, 11:53 PM
Mark's Avatar
Unhappy Mushkin
I've tried many different combination i
CHEERS
Old November 2, 2008, 07:05 AM
3.0charlie's Avatar
It's not the Ram... it's the 480FSB. You're pushing that QX9650, and stability at those speeds is very difficult to reach. 450 is usually tops.
I know, I had one too.
Hydro-Quebec is salivating...
Old November 2, 2008, 07:07 AM
Xilikon's Avatar
Agreed, 480x9 is pushing too far. Most will settle with 480-500x8 for 4 GHz. Above this, it's a crapshoot.
Xilikon - Team 33
Proud to be [H]ard !
Old November 2, 2008, 10:55 AM
MpG's Avatar
MpG MpG is offline
Thirded. The RAM isn't the problem here. You're just banging the uppers limits of your processor, especially for Prime95 stability. That 4.1 is quite nice, but anything beyond that is going to paid for in heat and processor life expectancy. For now, drop your FSB and raise your multi - your FSB is almost certainly maxed out, but you might have a little more headroom in the processor.
Old November 2, 2008, 12:53 PM
Mark's Avatar
Then I'll stick with 410 x 10 running 1649 stable. Keep in mind 480 x 8 was totally stable.
Thanks
Nice to have 2nd, 3rd or 4th opinions.
Cheers.
CHEERS
Old November 2, 2008, 01:02 PM
I'll add a fifth to agree.
Keep in mind also that 480FSB with 8 signals is less work that nine signals...
But I would up the FSB term votlage, as that board undervolts a tad, and PLL could go up as well. Altohugh, I highly doubt these will have any effect.
Old November 2, 2008, 01:41 PM
Mark's Avatar
Exclamation
What would be better? Place your bets on gaming, 3dmark, PI:
410x10 at 1600mhz or
500x7 at 1600mhz
I'll post results:)
CHEERS
Old November 2, 2008, 01:55 PM
lol 7x500 is 3.5ghz, 410x10 is 4.1ghz...4.1 should be better, but it kinda depends on a few things other than just FSB and cpu speed...
Old November 2, 2008, 02:03 PM
Mark's Avatar
it's not stable at 500 for forget it:)
CHEERS
