<~----> Using AsRock Untied Overclocking with an Intel SP79K ? - Hardware Canucks
Old May 4, 2007, 08:28 AM
Default Using AsRock Untied Overclocking with an Intel SP79K ?
Hi,
Is is safe and worth the trouble to activate the Untied Overclocking capabilities of my AsRock P4VM890 motherboard with an Intel SP79K Prescott HT 2.8 - 800 1M processor ? Processor temp rating is 69.1C. This beast already runs 10-15C hotter than a Northwood 2.6 with a standard CPU cooler. It is fast, but I don't want to fry it !!!
It currently runs at 46C with peaks of 54C, thanks to my new Zalman Ultra Quiet CPU cooler CNPS7700-ALCU (120mm controlled fan). It used to run 10C hotter with the standard intel CPU cooler. I only need the run the CPU fan at 1300RPM to keep the CPU and motherboard at that temp. I don't even need to run the case fan right now because the Okia Aluminum ATX 600W Power Supply I use has two very quiet fans that create enough airflow for now. It may be different in hot summer days.
I am not a gamer. The most demanding job I do is MP3 and MPG file editing, downloading MP3 files and backups ! I think the benefit of overclocking could be compromised by a much higher noise level from cooling fans, which is why so many of you guys go for liquid cooling solutions, right ? Is it worth the risk and trouble ?
Best regards,
Martin
I just dumped by ASRock 4Core DualVSTA KnSKranky CPU's and Motherboards 5 November 14, 2007 12:58 PM
ASRock 4Core 1333-eSATA2 R5.0 Intel P31 Motherboard Review @ Madshrimps SKYMTL Reviews & Articles from the Web 0 September 11, 2007 02:00 PM
Asrock 4coredual-vsta - blank screen josh_45 Troubleshooting 9 May 19, 2007 10:49 AM
ASRock 775DUAL-VSTA BALISTX CPU's and Motherboards 19 April 18, 2007 05:32 PM
