Old May 2, 2007, 08:27 PM
BALISTX's Avatar
Default DFI LANParty UT Ultra-D Overclock
Well I'll be getting my Ultra-D soon and would like some assistance with overclocking it.
Here are the crucial components.
AMD Operton 144 S939
Zalman 9500
DFI LANParty UT nForce Ultra-D S939
Crucial Ballistix PC3200 DDR400 @ 2-2-2-6 1T
Nmedia MP-500 500 Watt PSU
Heatware
HWBOT
Old May 3, 2007, 05:22 AM
Patriote's Avatar
Zalman 9500
Sounds good!
I'll help if i can. Although i don't have much experience with DFI boards, i know lots of ppls that does.
Have fun!
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old May 3, 2007, 05:45 AM
Supergrover's Avatar
sswilson last 939 was a DFI I belive so I am sure he'll have a few ideas
Getting pretty stoked eh KILLER?
R.I.P.
Old May 3, 2007, 07:07 AM
BALISTX's Avatar
Yep I am, now only if that money tree in the backyard would start producing more LOL
Heatware
HWBOT
Old May 3, 2007, 07:14 AM
Well, the standard settings to change are obviously:
HT multiplier: set this to 4x if you're within 200-250fsb, and 3x if you exceed 250.
RAM divider: Depending on how far that RAM can go, might as well put on the DDR333 or even the DDR266 divider... Don't be afraid to use a large divider to remain around DDR400 speeds... That way you can keep your timings as tight as possible, which is more beneficial to the A64 platform anyways (seeing as it's DIMM bandwidth is through the roof)
Make sure to lock the PCI bus at 33.3mhz (or whatever's closest) and the PCIe bus around 100-103mhz (you can vary this depending on stability, often 100mhz isn't fully stable, but 101 is)
Disable any spread spectrums first... Try re enabling them if you have instabilities you can't track down. They're normally BAD for overclocking.
And of course the many, many DFI specific settings that don't do all that much Those boards are incredible with what they let you control
00 - Sempron @ 2.4ghz| XP | Asus A8N-SLI | Asus 6200TC | 4x 500GB Seagates | 3x 250GB WD | 1gb POS RAM.
01 - E6300 @ 3430 | Water | XP | Asus P5B Deluxe | Evga 8800GTS @ 675/2100 |WD740ADFD + 2x 320gb eSata| 2gb Gskill HK 4-4-4-5 @ DDR2-960.
02 - Macbook Pro Dual 2.0 | Tiger/XP/Vista | Radeon X1600 256mb Vram | 1gb Ram | 8c Temp Drop w AS5.
DFI LanParty ICFX3200-T2R/G: TechGage Babrbarossa Reviews & Articles from the Web 4 May 22, 2007 03:42 PM
DFI's LANParty UT ICFX3200-T2R/G review by Tech Report Babrbarossa Reviews & Articles from the Web 2 April 3, 2007 07:17 AM
X-bit labs reviews DFI LANParty UT NF590 SLI-M2R/G Supergrover Reviews & Articles from the Web 0 December 27, 2006 04:10 PM
