Old October 18, 2008, 08:56 PM
8400s to reach 4gh can very easily require 1.4v of juice to get them there.
Biostar is a bit different with the voltage settings when it comes down to it and I find the easiest way to test the voltages is make a usb boot disk so that when its inserted and you reboot your computer you can see the voltages as you drop to a dos prompt.
Old October 18, 2008, 09:15 PM
Originally Posted by enaberif View Post
By saying things like this people are going to less likely want to help you.
Its saturday.. people are busy and aren't sitting around their computers.
Would you like help or are you going to keep being like this?
Ok I'm sorry I would like help instead please.. I forgot I'm one of the few who are getting bored, lots other are enjoying..
Ok Curt.. Please help..
What is the stock voltage of an E8400 how much + do I add to reach 1.40v please.
Old October 18, 2008, 09:20 PM
Stock is around 1.3 I think . I don't remember.
Just increase the voltage in the bios till you see it yellow then back it off a few.
If I recall its +0.020 .. which means take the 1.3 and add 0.20 to it which would give you 1.5v
But of course you don't want 1.5 :P
Old October 18, 2008, 09:35 PM
Increased the voltages:
And one more screenie, I loaded memtest still errors, anything I'm doing wrong..
Please and Thanks
Old October 18, 2008, 09:40 PM
- FSB to Northbridge Latch needs to be set
- DDR2 Speeds needs to be set
- DDR2 Enhance needs to be turned off
- Are your timings for your memory setup properly?
- CPU Voltage is still to low
Old October 18, 2008, 09:46 PM
Ok I have PC8500, memory so I set the FSB to NB to 1333
DDR2 speeds, is that DRAM Frequency
Timings are still an auto
CPU voltage I increased it one more step. Memtest 5 minutes no errors..
Old October 18, 2008, 10:00 PM
Yes you must set your DRAM Frequency.. You'll have a list of speeds in mhz to you so select which ever you feel the board will post at.. I say choose the lowest.
Timings MUST be set.
Old October 18, 2008, 10:04 PM
Oh ok.. Well do I have set all of them, or just the usual 5-5-5-12.. Sorry I almost new to using different timings..
  #19 (permalink)
Old October 18, 2008, 10:05 PM
Then your timings are set.
  #20 (permalink)
Old October 18, 2008, 10:37 PM
That's what I set, and 4ghz is reachable and stable so far.. Thanks Curt..
