Old October 17, 2008, 06:43 PM
nasrott's Avatar
Default amd 9950 @3 gig
Well finally got too 3 gig tonight been changing up hardware last couple weeks and seems was my cpu all this time that was holding me back, grabbed a 9950 tonight am at 15 times after a few reboots and tweak the voltage a little on this new core. Realize is not that big a deal but have never been this fast on amd before so am pretty impressed...
Running an Asus M3a79-t and 4 gig of Mushkin 1066 mem and a couple of 3870's in crossfire.
Old October 17, 2008, 09:14 PM
Nice warm up.
Wait till you give it some gas
AMD 9370FX
Asus Sabertooth 990FX
Gigabyte 7970 3GB
Patriot Viper 1833
PCP&C 750W
Win8 64bit
Custom W/C
Old October 17, 2008, 10:21 PM
Hey, long time no see Nas! Haven't bumped into you since theCrucible.ca forums a couple years ago.
Old October 17, 2008, 11:18 PM
nasrott's Avatar
Hey fracture, hows things? Yes been along time it has for sure, been awhile since Rob shut it down, think even more than 2 years ago now...
Old October 17, 2008, 11:27 PM
nasrott's Avatar
Originally Posted by Frank Encruncher View Post
Nice warm up.
what voltages are u running Frank? and on what exactly? Nice oc by the way..
Old October 18, 2008, 12:41 AM
For some reason I have pump vcore up to 1.55v when I start going over 3.0GHz, whlie I see other people only need 1.35v for 3.0-3.3 range and 1.45v over 3.3.
So I'm starting to suspect it has something do with my PSU
When I first started playing all I did was bump up the vcore
Set DDR voltage and mem speed
Then I just keep bumping up the multi, made to 17.5x
When you start playing with the ref. clock, NB mutli and HTT multi then you have to start bring up the other voltages.
Have fun
AMD 9370FX
Gigabyte 7970 3GB
Patriot Viper 1833
PCP&C 750W
Win8 64bit
Custom W/C
Old October 18, 2008, 02:02 AM
Killswitch's Avatar
I'm running a 125W 9950 with 1.35Vcore @ 3.2Ghz rock solid on the setup in my sig. I want to go for 3.4 Ghz but not until I get some slightly better cooling. I ran Prime95 tonight for 35 minutes and the cores topped out at 58oC. The cooler I'm running right now is an AC Freezer Pro 64. I have a Gigabyte G-Power to try out tomorrow. If it works out I might trade it for the Ultra-120 Extreme I have (couldn't use it because of mounting issues and air flow config :( ). Anyway, with its fan directed at the motherboard it'll be great for cooling the mosfets which are known to go up in smoke with this mobo! I have some ram sinks stuck to them right now and I'm hoping I NEVER have that problem arise.
Old October 18, 2008, 04:04 AM
nasrott's Avatar
Well I have a pretty decent sink it is the infinity Scythe, the cpu toped out @63c after prime was running most of the night, voltage I have tried up to 1.35 last night with no luck on both (could get into windows but not stable @ 3.1) so ya was wondering what v-core others with this set up were running...Will hit it again after I get a tea in me and throw so more juice at it... A swiftech kit is the next thing to get am too lazzy to get the homemade shit out of the boxes and want something clean looking not all sprawled out under my desks so ;)
Your ps Frank is concidered to be one the best you can get or least used to be wayback when maybe pcp+c has changed a bit since going more mainstream not sure.
Old November 12, 2008, 12:48 PM
chibi_man's Avatar
I got my 9950 at 3.314Ghz at around 1.440V just to keep it rock stable. My watercooling keeps the temp around 35C on average.
I can't seem to get it to hit 3.4 stable though. I have a funny feeling my Mushkin RAM is holding me back somewhere. I'll have to tweak it a little more.
_____________________________________
If you can't beat it... SMASH IT!!!
Old November 21, 2008, 12:52 PM
m1dget's Avatar
I got my 9850 stable at 3.37GHz with 1.45v iirc.
I had to drop it back to 3GHz because after 1.4v the mosfet of my board start to whine and it's annoying.
I'm curious for the ones OCing the phenom... are you using the good ol bios or amd overdrive?
BTW Frank... 1.55v to go over 3GHz is far from normal... I tested for about a week my 9850 at the default 1.289v for 3GHz and it was nealry stable (1-2 crash per 24 hours).
Something is wrong somewhere if you have to have need that much vcore
For 1.55, I think I could OC it to 3.5GHz (and hear my mosfet dying)...
"NIX is a classic example of security through obscurity because there is no real monetary reward for crackers and hackers to break Linix" -AkG
