View Poll Results: My favorite sandwich is?
peanut butter and jam 4 66.67%
sliced eyball and green ham 1 16.67%
toasted brazened boiled boils 0 0%
pork trife and tounges on rye 1 16.67%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old October 7, 2008, 09:14 PM
cmak's Avatar
Exclamation QX9650 vs x48T-DQ6 (giga-byte-MB)--OVERCLOCKING
Looking to bounce some ideas of off someone with the same mb/cpu.....
currently capped at 420*9=3.87
Voltage Values:
CPU Core 1.38 V
DIMM 1.82 V
turbo/extreme/pci100/cia-disabled
Motherboard 30 C (86 F)
CPU 34 C (93 F)
CPU #1 / Core #1 39 C (102 F)
CPU #1 / Core #2 39 C (102 F)
CPU #1 / Core #3 38 C (100 F)
CPU #1 / Core #4 38 C (100 F)
GPU1: GPU Diode (DispIO) 83 C (181 F)
GPU1: GPU Diode (MemIO) 99 C (210 F)
GPU1: GPU Diode (Shader) 90 C (194 F)
GPU1: GPU VRM 65 C (149 F)
GPU2: GPU Diode (DispIO) 56 C (133 F)
GPU2: GPU Diode (MemIO) 54 C (129 F)
GPU2: GPU Diode (Shader) 52 C (126 F)
GPU2: GPU VRM 53 C (127 F)
GPU3: GPU Diode (DispIO) 68 C (154 F)
GPU3: GPU Diode (MemIO) 69 C (156 F)
GPU3: GPU Diode (Shader) 69 C (156 F)
GPU3: GPU VRM 54 C (129 F)
GPU4: GPU Diode (DispIO) 54 C (129 F)
GPU4: GPU Diode (MemIO) 54 C (129 F)
GPU4: GPU Diode (Shader) 52 C (126 F)
GPU4: GPU VRM 52 C (126 F)
WDC WD3000GLFS-01F8U0 37 C (99 F)
qx9650
giga-byte:x48t-dq6
dual 4870X2 xfired (750/1000)
8GB Corsair XMS DDR3 999-24@666
V64
oc: 420x9 3.78Mhz
Coolit freezone Elite (cpu cooler)
Old October 8, 2008, 04:53 AM
MpG's Avatar
MpG MpG is offline
I have a different motherboard, but the same processor. It's possible that you need a little more voltage - many QX9650's need a full 1.400 vCore to reach the 4GHz mark. Also, if I'm not mistaken, there are a couple options in the X48 BIOS that pertain to clock skew, which are often needed in order to keep quad's stable at higher frequencies.
Old October 8, 2008, 04:59 AM
3.0charlie's Avatar
What MpG said - I needed to crack the 1.4V Vcore wall for my QX9650 to make it to 4.0, And it really liked the 8.5 multi, with a 450FSB (3.825 GHz, 1.33 Vcore). Go figure why.
Hydro-Quebec is salivating...
Old October 8, 2008, 07:28 AM
Phobia's Avatar
I heard that quads liked lower fsb's. So a higher multi and lower fsb. I have mine at 4.2 420 fsb x10 Unfortunately i don't remember what my vcore is, so i'm going to have to get back to you on that one. mine has hit a wall at 4.2 no matter if i raise the vcore. I'm thinking i have to raise the nb voltages, but im not that experienced at overclocking, so im going to leave it at 4.2
(whitty saying to be plagiarized at a later date)
Old October 8, 2008, 08:00 AM
420FSB is a common "hole" in X48 and QX9650, you need to either up VTT and chipset volts(as well as tweaking GTL with them), or you need to use a much lower memory divider.
Old October 8, 2008, 10:33 PM
cmak's Avatar
what is vtL, vtt and does low memory divider mean like 2:1.......? or is that high?
currently using 4B to utilize my 1600 memory...
thanks for your help.
d
qx9650
giga-byte:x48t-dq6
V64
oc: 420x9 3.78Mhz
Old October 9, 2008, 06:54 AM
VTT is FSB volts. and yes, running 420mhz FSB and 1680mhz ram is probably holding you back...I mean, 8 gigs is alot of ram for the chipset!
Also, first vga temps are quite high, what vgas?
Old October 9, 2008, 01:59 PM
cmak's Avatar
dual 4870x2s in crossfire, not OCd
pci at 100
do you think the chipset cant handle a full bundle of ram?
hmmm.
qx9650
giga-byte:x48t-dq6
V64
oc: 420x9 3.78Mhz
Old October 9, 2008, 02:06 PM
lol give up the FSB chase and up your multi, man. heh 4870x2's 8gb of ram, qx chip, freezone...
Really it depends, on which ram, but if not samsung, it's gonna have quite the draw...which means at that point you might need some high-level ram tweaking to get further...
