Originally Posted by RA3KW0N Some of us can have low temps by using different cooling methods, but have to pump more juice to obtain a high overclock because of CPU variations (e.g. high VIDs)..
others have good chips, and similar temps, because not as much voltage is being put into the CPU to obtain the same overclock..
my question is... in the long run, what is it that kills CPUs?
Excessive Voltage? Temps? Both?
I am aware that more voltage tends to mean higher temps... but let's say we all had access to liquid nitrogen cooling, would high voltages kill CPUs? |
Temps aren't as bad as most people think... but what do you consider excessive? Anything up to 70degrees shouldn't take too much life off your cpu. Over that, yes I would say effects would start to be worse as you rise, but your cpu will shut off automatically before the temps get so high that immediate damage is immanent.
Voltage on the other hand is up to you how much goes in. And anything beyond the voltage recommended by intel for instance is going to reduce the life of the cpu. But really when you think about it, like enaberif said you will reduce it from like 15-10 years, and will you be using this comp in 10 years anyways? Probably not.
Ps. The people who use liquid nitrogen to compete in overclocking contests do not OC on liquid nitrogen on a constant basis. These voltages would reduce the life of the processor dramatically if done often.
