  #21 (permalink)
Old September 17, 2008, 03:44 PM
Eldonko's Avatar
Hardware Canucks Reviewer
If you move to 1600 your FSB jumps to 400 which is likely too high.
DRAM freq setting in BIOS will not change if you inc FSB, it's basically a ratio, however, your actual RAM freq will (as shown in cpuz). That make sense?
  #22 (permalink)
Old September 17, 2008, 04:10 PM
electronique's Avatar
yes. Thanks :)
As shown in Bios, it is unchangeable - but the real ram freq changes automatically (if I inc FSB) and can be seen in prof softs. (cpu-z, freshdiagnose [...] )
