Old September 14, 2008, 01:24 PM
DK2 DK2 is offline
Default SPU (Stable Processing Unit)
xxxxx
Old September 14, 2008, 01:53 PM
Supergrover's Avatar
I'm on AMD, I'll give it a shot .....
R.I.P.
Old September 14, 2008, 02:01 PM
Okay it only detects 1 core on my phenom and it fails everytest
R.I.P.
Old September 14, 2008, 02:40 PM
RCKage's Avatar
But did it give you any errors?
"And thus I clothe my naked villany
With odd old ends stol'n out of holy writ,
And seem a saint, when most I play the devil."
Old September 14, 2008, 02:54 PM
R.I.P.
Old September 14, 2008, 02:57 PM
RCKage's Avatar
Not funny? Apologies
Old September 14, 2008, 02:59 PM
Oh no it was, I LOLed.
R.I.P.
Old September 14, 2008, 03:14 PM
DK2 DK2 is offline
xxxxx
Old September 14, 2008, 03:38 PM
Originally Posted by DK2 View Post
Ummm, donít worry about it.
If you go into the details it will tell you the errors codes of the test that failed.
If you could post the any errors codes, that would be great, or just what test group.
Sigh, now that I think of it, the whole error reporting thing needs a re-think,
As the main screen in the pic shows a count of any errors that happened in any test, itís a little deceiving.
Frankly this doesnít surprise me at all.
I could run it longer if you need it.
Code:
Register Pattern Test:
1 - 8 bit ah register failed standard test (8)
2 - 8 bit al register failed standard test (8)
3 - 8 bit bh register failed standard test (8)
4 - 8 bit bl register failed standard test (8)
5 - 8 bit ch register failed standard test (8)
6 - 8 bit cl register failed standard test (8)
7 - 8 bit dh register failed standard test (8)
8 - 8 bit dl register failed standard test (8)
11 - 8 bit ah register failed random test (1x4)
12 - 8 bit al register failed random test (1x4)
13 - 8 bit bh register failed random test (1x4)
14 - 8 bit bl register failed random test (1x4)
15 - 8 bit ch register failed random test (1x4)
16 - 8 bit cl register failed random test (1x4)
17 - 8 bit dh register failed random test (1x4)
18 - 8 bit dl register failed random test (1x4)
21 - 16 bit ax register failed standard test (7)
22 - 16 bit bx register failed standard test (7)
23 - 16 bit cx register failed standard test (7)
24 - 16 bit dx register failed standard test (7)
25 - 16 bit bp register failed standard test (7)
26 - 16 bit si register failed standard test (7)
27 - 16 bit di register failed standard test (7)
31 - 16 bit ax register failed random test (1x8)
32 - 16 bit bx register failed random test (1x8)
33 - 16 bit cx register failed random test (1x8)
34 - 16 bit dx register failed random test (1x8)
35 - 16 bit bp register failed random test (1x8)
36 - 16 bit si register failed random test (1x8)
37 - 16 bit di register failed random test (1x8)
41 - 32 bit eax register failed standard test (7)
42 - 32 bit ebx register failed standard test (7)
43 - 32 bit ecx register failed standard test (7)
44 - 32 bit edx register failed standard test (7)
45 - 32 bit ebp register failed standard test (7)
46 - 32 bit esi register failed standard test (7)
47 - 32 bit edi register failed standard test (7)
51 - 32 bit eax register failed random test (1x16)
52 - 32 bit ebx register failed random test (1x16)
53 - 32 bit ecx register failed random test (1x16)
54 - 32 bit edx register failed random test (1x16)
55 - 32 bit ebp register failed random test (1x16)
56 - 32 bit esi register failed random test (1x16)
57 - 32 bit edi register failed random test (1x16)
Data Transfer Test:
1 - 8 bit memory to ah register move failed random test (1x2)
2 - 8 bit memory to al register move failed random test (1x2)
3 - 8 bit memory to bh register move failed random test (1x2)
4 - 8 bit memory to bl register move failed random test (1x2)
5 - 8 bit memory to ch register move failed random test (1x2)
6 - 8 bit memory to cl register move failed random test (1x2)
7 - 8 bit memory to dh register move failed random test (1x2)
8 - 8 bit memory to dl register move failed random test (1x2)
21 - 8 bit register to ah register move failed random test (8*2)
22 - 8 bit register to al register move failed random test (8*2)
23 - 8 bit register to bh register move failed random test (8*2)
24 - 8 bit register to bl register move failed random test (8*2)
25 - 8 bit register to ch register move failed random test (8*2)
26 - 8 bit register to cl register move failed random test (8*2)
27 - 8 bit register to dh register move failed random test (8*2)
28 - 8 bit register to dl register move failed random test (8*2)
31 - 8 bit ah register to memory move failed random test (1x2)
32 - 8 bit al register to memory move failed random test (1x2)
33 - 8 bit bh register to memory move failed random test (1x2)
34 - 8 bit bl register to memory move failed random test (1x2)
35 - 8 bit ch register to memory move failed random test (1x2)
36 - 8 bit cl register to memory move failed random test (1x2)
37 - 8 bit dh register to memory move failed random test (1x2)
38 - 8 bit dl register to memory move failed random test (1x2)
41 - 8 bit immediate to memory move failed test (1x2)
42 - 8 bit immediate to memory move failed test (1x2)
43 - 8 bit immediate to memory move failed test (1x2)
44 - 8 bit immediate to memory move failed test (1x2)
45 - 8 bit immediate to memory move failed test (1x2)
46 - 8 bit immediate to memory move failed test (1x2)
47 - 8 bit immediate to memory move failed test (1x2)
48 - 8 bit immediate to memory move failed test (1x2)
101 - 16 bit memory to ax register move failed random test (1x4)
102 - 16 bit memory to bx register move failed random test (1x4)
103 - 16 bit memory to cx register move failed random test (1x4)
104 - 16 bit memory to dx register move failed random test (1x4)
105 - 16 bit memory to si register move failed random test (1x4)
106 - 16 bit memory to di register move failed random test (1x4)
121 - 16 bit register to ax register move failed random test (6x4)
122 - 16 bit register to bx register move failed random test (6x4)
123 - 16 bit register to cx register move failed random test (6x4)
124 - 16 bit register to dx register move failed random test (6x4)
125 - 16 bit register to si register move failed random test (6x4)
126 - 16 bit register to di register move failed random test (6x4)
131 - 16 bit ax register to memory move failed random test (1x4)
132 - 16 bit bx register to memory move failed random test (1x4)
133 - 16 bit cx register to memory move failed random test (1x4)
134 - 16 bit dx register to memory move failed random test (1x4)
135 - 16 bit si register to memory move failed random test (1x4)
136 - 16 bit di register to memory move failed random test (1x4)
141 - 16 bit immediate to memory move failed test (1x4)
142 - 16 bit immediate to memory move failed test (1x4)
143 - 16 bit immediate to memory move failed test (1x4)
144 - 16 bit immediate to memory move failed test (1x4)
145 - 16 bit immediate to memory move failed test (1x4)
146 - 16 bit immediate to memory move failed test (1x4)
201 - 32 bit memory to eax register move failed random test (1x8)
202 - 32 bit memory to ebx register move failed random test (1x8)
203 - 32 bit memory to ecx register move failed random test (1x8)
204 - 32 bit memory to edx register move failed random test (1x8)
205 - 32 bit memory to esi register move failed random test (1x8)
206 - 32 bit memory to edi register move failed random test (1x8)
221 - 32 bit register to eax register move failed random test (6x8)
222 - 32 bit register to ebx register move failed random test (6x8)
223 - 32 bit register to ecx register move failed random test (6x8)
224 - 32 bit register to edx register move failed random test (6x8)
225 - 32 bit register to esi register move failed random test (6x8)
226 - 32 bit register to edi register move failed random test (6x8)
231 - 32 bit eax register to memory move failed random test (1x8)
232 - 32 bit ebx register to memory move failed random test (1x8)
233 - 32 bit ecx register to memory move failed random test (1x8)
234 - 32 bit edx register to memory move failed random test (1x8)
235 - 32 bit esi register to memory move failed random test (1x8)
236 - 32 bit edi register to memory move failed random test (1x8)
241 - 32 bit immediate to memory move failed test (1x8)
242 - 32 bit immediate to memory move failed test (1x8)
243 - 32 bit immediate to memory move failed test (1x8)
244 - 32 bit immediate to memory move failed test (1x8)
245 - 32 bit immediate to memory move failed test (1x8)
246 - 32 bit immediate to memory move failed test (1x8)
Binary Arithmetic Tests
1 - 8 bit Add Immediate to register failed standard test (80)
2 - 8 bit Add w/carry immediate to register failed standard test (80)
3 - 8 bit Subtract immediate from register failed standard test (80)
4 - 8 bit Subtract w/borrow immediate from register failed standard test (80)
5 - 8 bit increment failed standard test (80)
6 - 8 bit decrement failed standard test (80)
7 - 8 bit negate failed standard test (80)
8 - 8 bit Arithmetic result failed standard test (16)
11 - 8 bit Add register to register failed standard test (560)
12 - 8 bit Add w/carry register to register failed standard test (560)
13 - 8 bit Subtract register from register failed standard test (560)
14 - 8 bit Subtract w/borrow register from register failed standard test (560)
15 - 8 bit increment failed standard test (560)
16 - 8 bit decrement failed standard test (560)
17 - 8 bit negate failed standard test (560)
18 - 8 bit Arithmetic result failed standard test (112)
21 - 8 bit Add register to memory failed standard test (80)
22 - 8 bit Add w/carry register to memory failed standard test (80)
23 - 8 bit Subtract register from memory failed standard test (80)
24 - 8 bit Subtract w/borrow register from memory failed standard test (80)
25 - 8 bit increment failed standard test (80)
26 - 8 bit decrement failed standard test (80)
27 - 8 bit negate failed standard test (80)
28 - 8 bit Arithmetic result failed standard test (16)
31 - 8 bit Add memory to register failed standard test (80)
32 - 8 bit Add w/carry memory to register failed standard test (80)
33 - 8 bit Subtract memory from register failed standard test (80)
34 - 8 bit Subtract w/borrow memory from register failed standard test (80)
35 - 8 bit increment failed standard test (80)
36 - 8 bit decrement failed standard test (80)
37 - 8 bit negate failed standard test (80)
38 - 8 bit Arithmetic result failed standard test (16)
41 - 8 bit Add Immediate to memory failed standard test (10)
42 - 8 bit Add w/carry immediate to memory failed standard test (10)
43 - 8 bit Subtract immediate from memory failed standard test (10)
44 - 8 bit Subtract w/borrow immediate from memory failed standard test (10)
45 - 8 bit increment failed standard test (10)
46 - 8 bit decrement failed standard test (10)
47 - 8 bit negate failed standard test (10)
48 - 8 bit Arithmetic result failed standard test (10)
51 - 8 bit unsigned multiply failed (24)
52 - 8 bit unsigned multiply result failed (12)
53 - 8 bit unsigned divide failed (12)
54 - 8 bit signed multiply result failed (24)
55 - 8 bit signed divide failed (12)
61 - 8 bit Arithmetic operation on ah register failed random test (1x2)
62 - 8 bit Arithmetic operation on al register failed random test (1x2)
63 - 8 bit Arithmetic operation on bh register failed random test (1x2)
64 - 8 bit Arithmetic operation on bl register failed random test (1x2)
65 - 8 bit Arithmetic operation on ch register failed random test (1x2)
66 - 8 bit Arithmetic operation on cl register failed random test (1x2)
67 - 8 bit Arithmetic operation on dh register failed random test (1x2)
68 - 8 bit Arithmetic operation on dl register failed random test (1x2)
101 - 16 bit Add Immediate to register failed standard test (70)
102 - 16 bit Add w/carry immediate to register failed standard test (70)
103 - 16 bit Subtract immediate from register failed standard test (70)
104 - 16 bit Subtract w/borrow immediate from register failed standard test (70)
105 - 16 bit increment failed standard test (70)
106 - 16 bit decrement failed standard test (70)
107 - 16 bit negate failed standard test (70)
108 - 16 bit Arithmetic result failed standard test (14)
111 - 16 bit Add register to register failed standard test (420)
112 - 16 bit Add w/carry register to register failed standard test (420)
113 - 16 bit Subtract register from register failed standard test (420)
114 - 16 bit Subtract w/borrow register from register failed standard test (420)
115 - 16 bit increment failed standard test (420)
116 - 16 bit decrement failed standard test (420)
117 - 16 bit negate failed standard test (420)
118 - 16 bit Arithmetic result failed standard test (84)
121 - 16 bit Add register to memory failed standard test (70)
122 - 16 bit Add w/carry register to memory failed standard test (70)
123 - 16 bit Subtract register from memory failed standard test (70)
124 - 16 bit Subtract w/borrow register from memory failed standard test (70)
125 - 16 bit increment failed standard test (70)
126 - 16 bit decrement failed standard test (70)
127 - 16 bit negate failed standard test (70)
128 - 16 bit Arithmetic result failed standard test (14)
131 - 16 bit Add memory to register failed standard test (70)
132 - 16 bit Add w/carry memory to register failed standard test (70)
133 - 16 bit Subtract memory from register failed standard test (70)
134 - 16 bit Subtract w/borrow memory from register failed standard test (70)
135 - 16 bit increment failed standard test (70)
136 - 16 bit decrement failed standard test (70)
137 - 16 bit negate failed standard test (70)
138 - 16 bit Arithmetic result failed standard test (14)
141 - 16 bit Add immediate to memory failed standard test
142 - 16 bit Add w/carry immediate to memory failed standard test
143 - 16 bit Subtract immediate from memory failed standard test
144 - 16 bit Subtract w/borrow immediate from memory failed standard test
145 - 16 bit increment failed standard test
146 - 16 bit decrement failed standard test
147 - 16 bit negate failed standard test
148 - 16 bit Arithmetic result failed standard test
151 - 16 bit unsigned multiply failed
152 - 16 bit unsigned multiply result failed
153 - 16 bit unsigned divide failed
154 - 16 bit signed multiply result failed
155 - 16 bit signed divide failed
161 - 16 bit Arithmetic operation on ax register failed random test
162 - 16 bit Arithmetic operation on bx register failed random test
163 - 16 bit Arithmetic operation on cx register failed random test
164 - 16 bit Arithmetic operation on dx register failed random test
165 - 16 bit Arithmetic operation on si register failed random test
166 - 16 bit Arithmetic operation on di register failed random test
201 - 32 bit Add Immediate to register failed standard test
202 - 32 bit Add w/carry immediate to register failed standard test
203 - 32 bit Subtract immediate from register failed standard test
204 - 32 bit Subtract w/borrow immediate from register failed standard test
205 - 32 bit increment failed standard test
206 - 32 bit decrement failed standard test
207 - 32 bit negate failed standard test
208 - 32 bit Arithmetic result failed standard test
211 - 32 bit Add register to register failed standard test
212 - 32 bit Add w/carry register to register failed standard test
213 - 32 bit Subtract register from register failed standard test
214 - 32 bit Subtract w/borrow register from register failed standard test
215 - 32 bit increment failed standard test
216 - 32 bit decrement failed standard test
217 - 32 bit negate failed standard test
218 - 32 bit Arithmetic result failed standard test
221 - 32 bit Add register to memory failed standard test
222 - 32 bit Add w/carry register to memory failed standard test
223 - 32 bit Subtract register from memory failed standard test
224 - 32 bit Subtract w/borrow register from memory failed standard test
225 - 32 bit increment failed standard test
226 - 32 bit decrement failed standard test
227 - 32 bit negate failed standard test
228 - 32 bit Arithmetic result failed standard test
231 - 32 bit Add memory to register failed standard test
232 - 32 bit Add w/carry memory to register failed standard test
233 - 32 bit Subtract memory from register failed standard test
234 - 32 bit Subtract w/borrow memory from register failed standard test
235 - 32 bit increment failed standard test
236 - 32 bit decrement failed standard test
237 - 32 bit negate failed standard test
238 - 32 bit Arithmetic result failed standard test
241 - 32 bit Add immediate to memory failed standard test
242 - 32 bit Add w/carry immediate to memory failed standard test
243 - 32 bit Subtract immediate from memory failed standard test
244 - 32 bit Subtract w/borrow immediate from memory failed standard test
245 - 32 bit increment failed standard test
246 - 32 bit decrement failed standard test
247 - 32 bit negate failed standard test
248 - 32 bit Arithmetic result failed standard test
251 - 32 bit unsigned multiply failed
252 - 32 bit unsigned multiply result failed
253 - 32 bit unsigned divide failed
254 - 32 bit signed multiply result failed
255 - 32 bit signed divide failed
261 - 32 bit Arithmetic operation on ah register failed random test
262 - 32 bit Arithmetic operation on al register failed random test
263 - 32 bit Arithmetic operation on bh register failed random test
264 - 32 bit Arithmetic operation on bl register failed random test
265 - 32 bit Arithmetic operation on ch register failed random test
266 - 32 bit Arithmetic operation on cl register failed random test
267 - 32 bit Arithmetic operation on dh register failed random test
268 - 32 bit Arithmetic operation on dl register failed random test
Decimal Arithmetic Tests
1 - 8 bit no carry test failed
2 - 8 bit carry test failed
Logical Tests
1 - 8 bit register AND immediate failed standard test #1
2 - 8 bit register AND immediate failed standard test #2
3 - 8 bit register OR immedaite failed standard test
4 - 8 bit register XOR immedaite failed standard test
5 - 8 bit register NOT failed standard test
11 - 8 bit register AND random data failed test
12 - 8 bit register NOT with random data failed test
13 - 8 bit register OR random data failed test
14 - 8 bit register XOR random data failed test
15 - 8 bit logical result failed test
21 - 16 bit register AND immediate failed standard test #1
22 - 16 bit register AND immediate failed standard test #2
23 - 16 bit register OR immedaite failed standard test
24 - 16 bit register XOR immedaite failed standard test
25 - 16 bit register NOT failed standard test
31 - 16 bit register AND random data failed test
32 - 16 bit register NOT with random data failed test
33 - 16 bit register OR random data failed test
34 - 16 bit register XOR random data failed test
35 - 16 bit logical result failed test
41 - 32 bit register AND immediate failed standard test #1
42 - 32 bit register AND immediate failed standard test #2
43 - 32 bit register OR immedaite failed standard test
44 - 32 bit register XOR immedaite failed standard test
45 - 32 bit register NOT failed standard test
51 - 32 bit register AND random data failed test
52 - 32 bit register NOT with random data failed test
53 - 32 bit register OR random data failed test
54 - 32 bit register XOR random data failed test
55 - 32 bit logical result failed test
Shift and Rotate Tests
1 - 8 bit Shift arithmetic Left with immediate failed standard test
2 - 8 bit Shift logical Left with immediate failed standard test
3 - 8 bit Shift arithmetic Right with immedaite failed standard test
4 - 8 bit Shift logical Right with immedaite failed standard test
5 - 8 bit Roll Left with immediate failed standard test
6 - 8 bit Roll Right with immediate failed standard test
7 - 8 bit Roll Right carry with immediate failed standard test
8 - 8 bit Roll Left carry with immediate failed standard test
9 - 8 bit Shift and Roll Result with immediate failed standard test
11 - 8 bit Multi Shift arithmetic Left with immediate failed standard test
12 - 8 bit Multi Shift logical Left with immediate failed standard test
13 - 8 bit Multi Shift arithmetic Right with immedaite failed standard test
14 - 8 bit Multi Shift logical Right with immedaite failed standard test
15 - 8 bit Multi Roll Left with immediate failed standard test
16 - 8 bit Multi Roll Right with immediate failed standard test
17 - 8 bit Multi Roll Right carry with immediate failed standard test
18 - 8 bit Multi Roll Left carry with immediate failed standard test
19 - 8 bit Multi Shift and Roll Result with immediate failed standard test
21 - 8 bit Multi cl Shift arithmetic Left with immediate failed standard test
22 - 8 bit Multi cl Shift logical Left with immediate failed standard test
23 - 8 bit Multi cl Shift arithmetic Right with immedaite failed standard test
24 - 8 bit Multi cl Shift logical Right with immedaite failed standard test
25 - 8 bit Multi cl Roll Left with immediate failed standard test
26 - 8 bit Multi cl Roll Right with immediate failed standard test
27 - 8 bit Multi cl Roll Right carry with immediate failed standard test
28 - 8 bit Multi cl Roll Left carry with immediate failed standard test
29 - 8 bit Multi cl Shift and Roll Result with immediate failed standard test
31 - 8 bit Shift Left and Right, Roll Left and Right failed Random test
32 - 8 bit Shift Left and Right, Roll Left and Right Memory failed Random test
101 - 16 bit Shift arithmetic Left with immediate failed standard test
102 - 16 bit Shift logical Left with immediate failed standard test
103 - 16 bit Shift arithmetic Right with immedaite failed standard test
104 - 16 bit Shift logical Right with immedaite failed standard test
105 - 16 bit Roll Left with immediate failed standard test
106 - 16 bit Roll Right with immediate failed standard test
107 - 16 bit Roll Right carry with immediate failed standard test
108 - 16 bit Roll Left carry with immediate failed standard test
109 - 16 bit Shift and Roll Result with immediate failed standard test
111 - 16 bit Multi Shift arithmetic Left with immediate failed standard test
112 - 16 bit Multi Shift logical Left with immediate failed standard test
113 - 16 bit Multi Shift arithmetic Right with immedaite failed standard test
114 - 16 bit Multi Shift logical Right with immedaite failed standard test
115 - 16 bit Multi Roll Left with immediate failed standard test
116 - 16 bit Multi Roll Right with immediate failed standard test
117 - 16 bit Multi Roll Right carry with immediate failed standard test
118 - 16 bit Multi Roll Left carry with immediate failed standard test
119 - 16 bit Multi Shift and Roll Result with immediate failed standard test
121 - 16 bit Multi cl Shift arithmetic Left with immediate failed standard test
122 - 16 bit Multi cl Shift logical Left with immediate failed standard test
123 - 16 bit Multi cl Shift arithmetic Right with immedaite failed standard test
124 - 16 bit Multi cl Shift logical Right with immedaite failed standard test
125 - 16 bit Multi cl Roll Left with immediate failed standard test
126 - 16 bit Multi cl Roll Right with immediate failed standard test
127 - 16 bit Multi cl Roll Right carry with immediate failed standard test
128 - 16 bit Multi cl Roll Left carry with immediate failed standard test
129 - 16 bit Multi cl Shift and Roll Result with immediate failed standard test
131 - 16 bit Shift Left and Right, Roll Left and Right failed Random test
132 - 16 bit Shift Left and Right, Roll Left and Right Memory failed Random test
201 - 32 bit Shift arithmetic Left with immediate failed standard test
202 - 32 bit Shift logical Left with immediate failed standard test
203 - 32 bit Shift arithmetic Right with immedaite failed standard test
204 - 32 bit Shift logical Right with immedaite failed standard test
205 - 32 bit Roll Left with immediate failed standard test
206 - 32 bit Roll Right with immediate failed standard test
207 - 32 bit Roll Right carry with immediate failed standard test
208 - 32 bit Roll Left carry with immediate failed standard test
209 - 32 bit Shift and Roll Result with immediate failed standard test
211 - 32 bit Multi Shift arithmetic Left with immediate failed standard test
212 - 32 bit Multi Shift logical Left with immediate failed standard test
213 - 32 bit Multi Shift arithmetic Right with immedaite failed standard test
214 - 32 bit Multi Shift logical Right with immedaite failed standard test
215 - 32 bit Multi Roll Left with immediate failed standard test
216 - 32 bit Multi Roll Right with immediate failed standard test
217 - 32 bit Multi Roll Right carry with immediate failed standard test
218 - 32 bit Multi Roll Left carry with immediate failed standard test
219 - 32 bit Multi Shift and Roll Result with immediate failed standard test
221 - 32 bit Multi cl Shift arithmetic Left with immediate failed standard test
222 - 32 bit Multi cl Shift logical Left with immediate failed standard test
223 - 32 bit Multi cl Shift arithmetic Right with immedaite failed standard test
224 - 32 bit Multi cl Shift logical Right with immedaite failed standard test
225 - 32 bit Multi cl Roll Left with immediate failed standard test
226 - 32 bit Multi cl Roll Right with immediate failed standard test
227 - 32 bit Multi cl Roll Right carry with immediate failed standard test
228 - 32 bit Multi cl Roll Left carry with immediate failed standard test
229 - 32 bit Multi cl Shift and Roll Result with immediate failed standard test
231 - 32 bit Shift Left and Right, Roll Left and Right failed Random test
232 - 32 bit Shift Left and Right, Roll Left and Right Memory failed Random test
Bit and Byte Tests
1 - 8 bit register with immediate data, sign flag error
2 - 8 bit register with immediate data, zero flag error
3 - 8 bit register with immediate data, parity error
4 - 8 bit register with register data, sign flag error
5 - 8 bit register with register data, zero flag error
6 - 8 bit register with register data, parity flag error
7 - 8 bit memory with register data, sign flag error
8 - 8 bit memory with register data, zero flag error
9 - 8 bit memory with register data, parity flag error
11 - 8 bit ah bit condition set error
12 - 8 bit ah bit condition clear error
13 - 8 bit al bit condition set error
14 - 8 bit al bit condition clear error
15 - 8 bit bh bit condition set error
16 - 8 bit bh bit condition clear error
17 - 8 bit bl bit condition set error
18 - 8 bit bl ah bit condition clear error
19 - 8 bit ch bit condition set error
20 - 8 bit ch bit condition clear error
21 - 8 bit cl bit condition set error
22 - 8 bit cl bit condition clear error
23 - 8 bit dh bit condition set error
24 - 8 bit dh bit condition clear error
25 - 8 bit dl bit condition set error
26 - 8 bit dl bit condition clear error
101 - 16 bit register with immediate data, sign flag error
102 - 16 bit register with immediate data, zero flag error
103 - 16 bit register with immediate data, parity flag error
104 - 16 bit register with register data, sign flag error
105 - 16 bit register with register data, zero flag error
106 - 16 bit register with register data, parity flag error
107 - 16 bit memory with register data, sign flag error
108 - 16 bit memory with register data, zero flag error
109 - 16 bit memory with register data, parity flag error
110 - 16 bit ax bit store error
111 - 16 bit bx bit store error
112 - 16 bit cx bit store error
113 - 16 bit dx bit store error
114 - 16 bit bp bit store error
115 - 16 bit si bit store error
116 - 16 bit di bit store error
120 - 16 bit ax bit flag error
121 - 16 bit ax bit location error
122 - 16 bit bx bit flag error
123 - 16 bit bx bit location error
124 - 16 bit cx bit flag error
125 - 16 bit cx bit location error
126 - 16 bit dx bit flag error
127 - 16 bit dx bit location error
128 - 16 bit bp bit flag error
129 - 16 bit bp bit location error
130 - 16 bit si bit flag error
131 - 16 bit si bit location error
132 - 16 bit di bit flag error
133 - 16 bit di bit location error
140 - 16 bit ax bit scan flag error
141 - 16 bit ax bit scan result error
142 - 16 bit bx bit scan flag error
143 - 16 bit bx bit scan result error
144 - 16 bit cx bit scan flag error
145 - 16 bit cx bit scan result error
146 - 16 bit dx bit scan flag error
147 - 16 bit dx bit scan result error
148 - 16 bit bp bit scan flag error
149 - 16 bit bp bit scan result error
150 - 16 bit si bit scan flag error
151 - 16 bit si bit scan result error
152 - 16 bit di bit scan flag error
153 - 16 bit di bit scan result error
201 - 32 bit register with immediate data, sign flag error
202 - 32 bit register with immediate data, zero flag error
203 - 32 bit register with immediate data, parity flag error
204 - 32 bit register with register data, sign flag error
205 - 32 bit register with register data, zero flag error
206 - 32 bit register with register data, parity flag error
207 - 32 bit memory with register data, sign flag error
208 - 32 bit memory with register data, zero flag error
209 - 32 bit memory with register data, parity flag error
210 - 32 bit ax bit store error
211 - 32 bit bx bit store error
212 - 32 bit cx bit store error
213 - 32 bit dx bit store error
214 - 32 bit bp bit store error
215 - 32 bit si bit store error
216 - 32 bit di bit store error
220 - 32 bit ax bit flag error
221 - 32 bit ax bit location error
222 - 32 bit bx bit flag error
223 - 32 bit bx bit location error
224 - 32 bit cx bit flag error
225 - 32 bit cx bit location error
226 - 32 bit dx bit flag error
227 - 32 bit dx bit location error
228 - 32 bit bp bit flag error
229 - 32 bit bp bit location error
230 - 32 bit si bit flag error
231 - 32 bit si bit location error
232 - 32 bit di bit flag error
233 - 32 bit di bit location error
240 - 32 bit ax bit scan flag error
241 - 32 bit ax bit scan result error
242 - 32 bit bx bit scan flag error
243 - 32 bit bx bit scan result error
244 - 32 bit cx bit scan flag error
245 - 32 bit cx bit scan result error
246 - 32 bit dx bit scan flag error
247 - 32 bit dx bit scan result error
248 - 32 bit bp bit scan flag error
249 - 32 bit bp bit scan result error
250 - 32 bit si bit scan flag error
251 - 32 bit si bit scan result error
252 - 32 bit di bit scan flag error
253 - 32 bit di bit scan result error
Control Transfer Tests
1 - jmp test failed
2 - jmp zero condition failed
3 - jmp above condition failed
4 - jmp above equal condition failed
5 - jmp greater condition failed
6 - jmp greater equal condition failed
7 - jmp less than condition failed
8 - jmp less than equal condition failed
9 - jmp carry condition failed
10 - jmp overflow condition failed
11 - jmp sign condition failed
12 - jmp parity condition failed
13 - jmp cx/ecx zero condition failed
14 - loop condition failed
15 - loop not zero condtion failed
16 - loop zero condition failed
String Tests
1 - 8 bit forward string move failed
2 - 8 bit forward move string pointer failed
3 - 8 bit forward string compare failed
4 - 8 bit forward string compare pointer failed
5 - 8 bit forward string scan failed
6 - 8 bit forward string scan pointer failed
11 - 8 bit reverse string move failed
12 - 8 bit reverse move string pointer failed
13 - 8 bit reverse string compare failed
14 - 8 bit reverse string compare pointer failed
15 - 8 bit reverse string scan failed
16 - 8 bit reverse string scan pointer failed
101 - 16 bit forward string move failed
102 - 16 bit forward move string pointer failed
103 - 16 bit forward string compare failed
104 - 16 bit forward string compare pointer failed
105 - 16 bit forward string scan failed
106 - 16 bit forward string scan pointer failed
111 - 16 bit reverse string move failed
112 - 16 bit reverse move string pointer failed
113 - 16 bit reverse string compare failed
114 - 16 bit reverse string compare pointer failed
115 - 16 bit reverse string scan failed
116 - 16 bit reverse string scan pointer failed
201 - 32 bit forward string move failed
202 - 32 bit forward move string pointer failed
203 - 32 bit forward string compare failed
204 - 32 bit forward string compare pointer failed
205 - 32 bit forward string scan failed
206 - 32 bit forward string scan pointer failed
211 - 32 bit reverse string move failed
212 - 32 bit reverse move string pointer failed
213 - 32 bit reverse string compare failed
214 - 32 bit reverse string compare pointer failed
215 - 32 bit reverse string scan failed
216 - 32 bit reverse string scan pointer failed
I/O Tests
Enter and Leave Tests
Flag Control Tests
1 - clear carry flag failed
2 - set carry flag failed
3 - compliment carry failed
4 - clear direction flag failed
5 - set direction flag failed
6 - flag storage test failed
Segment Register Tests
Miscellaneous Tests
FPU (Floating Point Unit) X87 Tests
1 - 32 bit multiply divide failed
2 - 32 bit add subtract failed
5 - 32 bit Log10 random precision test failed
6 - 32 bit Log2 random precision test failed
7 - 32 bit LogN random precision test failed
10 - 32 bit Sine random precision tests failed
11 - 32 bit Cosine random precision tests failed
12 - 32 bit Tangent random precision tests failed
13 - 32 bit Secant random precision tests failed
14 - 32 bit Cosecant random precision tests failed
15 - 32 bit Cotangent random precision tests failed
16 - 32 bit Integer powers random precision test failed
21 - 32 bit PI failed
22 - 32 bit 1.0 failed
23 - 32 bit Log210 failed
24 - 32 bit Log2e failed
25 - 32 bit Log102 failed
26 - 32 bit Loge2 failed
27 - 32 bit 0.0 failed
101 - 64 bit multiply divide failed
102 - 64 bit add subtract failed
105 - 64 bit Log10 random precision test failed
106 - 64 bit Log2 random precision test failed
107 - 64 bit LogN random precision test failed
110 - 64 bit Sine random precision tests failed
111 - 64 bit Cosine random precision tests failed
112 - 64 bit Tangent random precision tests failed
113 - 64 bit Secant random precision tests failed
114 - 64 bit Cosecant random precision tests failed
115 - 64 bit Cotangent random precision tests failed
116 - 64 bit Integer powers random precision test failed
121 - 64 bit PI failed
122 - 64 bit 1.0 failed
123 - 64 bit Log210 failed
124 - 64 bit Log2e failed
125 - 64 bit Log102 failed
126 - 64 bit Loge2 failed
127 - 64 bit 0.0 failed
201 - 80 bit multiply divide failed
202 - 80 bit add subtract failed
205 - 80 bit Log10 random precision test failed
206 - 80 bit Log2 random precision test failed
207 - 80 bit LogN random precision test failed
210 - 80 bit Sine random precision tests failed
211 - 80 bit Cosine random precision tests failed
212 - 80 bit Tangent random precision tests failed
213 - 80 bit Secant random precision tests failed
214 - 80 bit Cosecant random precision tests failed
215 - 80 bit Cotangent random precision tests failed
216 - 80 bit Integer powers random precision test failed
221 - 80 bit PI failed
222 - 80 bit 1.0 failed
223 - 80 bit Log210 failed
224 - 80 bit Log2e failed
225 - 80 bit Log102 failed
226 - 80 bit Loge2 failed
227 - 80 bit 0.0 failed
R.I.P.
Old September 14, 2008, 04:42 PM
DK2 DK2 is offline
xxxxx
