Old April 23, 2007, 04:46 PM
Default Multi-PI for multi-cores?
Is sombody knows where to download a multi-PI program that work for multi-cores system ?
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
Old April 23, 2007, 04:59 PM
sswilson's Avatar
On XP at least Super-Pi worked both cores on my new chip.
Old April 23, 2007, 05:03 PM
...I was asking because somebody told me today that SuperPI is old and single CPU driven!
Old April 23, 2007, 05:10 PM
sswilson's Avatar
I don't believe it is specifically optimized for two cores, but the workload is dropped across both.
The #s we see posted for super-pi (that intel now kicks serious butt with) are for the normal super-pi. (at least as far as I can tell).
b1lk1's Avatar
You need to run multiple instances of it under XP and set the affinity to each core for each instance to get it to work. I am not sure what program you used Swilson, but I have yet to see a PI program that is multi-cored natively.
MY HEATWARE
Old April 23, 2007, 05:16 PM
sswilson's Avatar
When I run mod 1.4 both cores show about 50% usage.
Old April 23, 2007, 05:26 PM
I run SuperPI with affinity set on one CPU and compare with affinity set on all 4 CPU...the result is the same!
What do you mean by multiple instances...is it to open multiples SuperPI? ...and then what?
Old April 23, 2007, 07:35 PM
b1lk1's Avatar
If you want 100% load from SuperPI, you need to open as many instances as you have cores. Then in task manager, set each instance to a specific core, 1-4. Then start 4 PI runs. If there is ANY instability in your overclock it will show up fast.
MY HEATWARE
Old April 24, 2007, 06:32 AM
I openned 4 instances of Super PI and set the affinity on each core.
No matther what I do, only one core is not in error. All others cores produces errors when they run at the same time. I tried 2, 3 and 4 instances and only one core give a good results. I can run stable for 4 hours with Orthos on all four cores???
...is Super PI a better tool for stability? One good thing will be that it can test in less than 40 seconds...(if I select 2M) compare to Orthos!
Old April 24, 2007, 03:28 PM
Scratch's Avatar
Socket 775 Oc Competition Thread - OverclockersClub Forums
RAM vs Mhz for Multi-Monitoring Lyxtwing Video Cards 6 January 23, 2008 08:53 AM
Single vs Multi rail PSU's durdy Power Supplies 1 December 30, 2007 08:16 AM
ATI May Be Considering “Multi-Die GPUs” for R700 Family Shadowmeph Press Releases & Tech News 0 December 7, 2007 10:38 AM
Windows XP multi core optimization from MS Eldonko O/S's, Drivers & General Software 5 October 1, 2007 07:35 PM
