Originally Posted by francois methot I openned 4 instances of Super PI and set the affinity on each core.
No matther what I do, only one core is not in error. All others cores produces errors when they run at the same time. I tried 2, 3 and 4 instances and only one core give a good results. I can run stable for 4 hours with Orthos on all four cores???
...is Super PI a better tool for stability? One good thing will be that it can test in less than 40 seconds...(if I select 2M) compare to Orthos! |
I would say if you can run 4 hours Orthos then your PC is somewhat stable. You really should be able to run 4 instances of PI if your PC is 100% stable. There are so many other factors, I wouldn't worry too much. But if you want to be sure of perfect stability, run Orthos for 24hrs+. That is the best proof of a truely stable system.
