Go Back   Hardware Canucks > HARDWARE > Optical Drives
LinkBack (1) Thread Tools Display Modes
  #21 (permalink)
Old October 7, 2008, 05:14 PM
Level up: 20% Level up: 20% Level up: 20%
Level: 9 - 188 points to level up
Do blue ray drives for PC's come with programs for watching blu ray movies?
GAMING RIG:
Intel E8400 45nm Wolfdale Core 2 Duo @ 3GHz 1333MHz FSB w/ OCZ Vendetta II
4GB DDR 2 800MHz (OCZ Platinum)
Main: 160GB SATAII (Seagate) Storage: 500GB SATAII (WD)
Radeon Sapphire HD4850
610W PC Power Silencer
Asus P5Q SE
  #22 (permalink)
Old October 7, 2008, 05:27 PM
Babrbarossa's Avatar
Super Moderator
Yup- I bought that LG at F.S. for 139 two weeks ago- I'm not usually a big LG fan, but options are few in that price range.
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
  #23 (permalink)
Old October 7, 2008, 05:50 PM
Level up: 97% Level up: 97% Level up: 97%
Level: 13 - 16 points to level up
Ditto here....Lg comes with Cyberlink Power DVD 7. Been using one for about 10 or more months
Amd FX60 @2.9
Asus A8R32-MVP Deluxe
2 Gig Corsair XMS 4000PT
2 Ati X1900's @XTX Speeds
2 WD 160gg HD's in Raid 0
XFi Platinum
Tt 680 Watt PSU
SATA Plextor DVD
(Liquid Cooled) Swiftech Apex Ultra and 2 MCW 60's
Kandalf
  #24 (permalink)
Old October 14, 2008, 02:01 PM
Level up: 41% Level up: 41% Level up: 41%
Level: 14 - 348 points to level up
Originally Posted by Kaizer Soze View Post
I have seen some for $250 up to $400, not TOO bad but still fairly pricey. As said before, if you are building an HTPC it would be a great advantage, but otherwise, there's really no point to it. Although, I must admit, Blu-Ray in 1080p looks way better than just normal 1080i, it's much more sharper, color is more vivid, image is...crisp.
I heard Blu-Ray manufacturers like to boast that if you are watching a movie and a grenade blows up, you get to see every little piece of shrapnel flying through the air. I just thought: "Well, is anyone going to be sitting there 4 inches from their TV screen counting every little bit that is like 2 square pixels big? They pause it every half a second and count: 1,2,3,4,5... XD"
I don't need to as my 1080P display is adjustable from 35-150" :) But i can say that if someone were looking for a blueray player get a PS3 :)
Intel Core 2 Duo E8400 3.00GHZ 45nm | Asus P5Q Pro | 500GB Seagate Sata II | E-VGA Geforce 9800GX2 | Antec 300 | Corsair TX750 | 6GB G.Skill PC-8500 DDR2
  #25 (permalink)
Old October 14, 2008, 02:46 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I have a bluray in my ps3, not that I use it. I dunno if Im blind or what but it looks the same as dvd to me lol.
Hockey Mod at your service
  #26 (permalink)
Old October 14, 2008, 02:55 PM
Well i have but then again my setup is kinda rediculous. You would need to make sure of the following.
1. Your tv is a 1080P 120Hz or higher also called 24p.
2. Make sure your using an HDMI cable 1.3a would be best.
3. Also make sure the dvd content is a tru 1080 source not a remastered one. Choose a new release on bluray. Consider any recent new release such as ironman, kingdom of heavern or the upcoming dark knight release.
For those interested here is my hi def setup.
PS3 -> yamaha reciever -> epson powerlite 1080P UB Projector. (it's a 24p projector)
  #27 (permalink)
Old October 14, 2008, 03:07 PM
Eldonko's Avatar
Yeah its my tv, its 720 not 1080. All Blu Ray is to me is an extra dollar at Blockbuster right now.
  #28 (permalink)
Old October 14, 2008, 07:25 PM
and thats why you don't see much of a difference. load that sucker up on a 1080 24p tv and there is a big difference.
  #29 (permalink)
Old October 14, 2008, 08:54 PM
lowfat's Avatar
Level up: 65% Level up: 65% Level up: 65%
Level: 14 - 205 points to level up
That software it comes with is crippled. It doesn't support any of the HD audio codecs.
  #30 (permalink)
Old October 14, 2008, 08:56 PM
lowfat's Avatar
It really depends on the transfer. A good transfer can still look amazing on a 720p display. I watched Blade Runner on a 37" 720p display and it looked absolutely amazing.
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/optical-drives/6946-do-we-need-blu-ray.html
Posted By For Type Date
The blog of Björn Johansson This thread Refback July 19, 2008 09:09 AM
