Go Back   Hardware Canucks > HARDWARE > Optical Drives
Old May 3, 2008, 05:29 AM
FrankyG's Avatar
Level up: 28% Level up: 28% Level up: 28%
Level: 9 - 170 points to level up
Default DVD Drive caushing blue screen of death ?
hi all,
I have a LG G-H20L-S10 SATA DVD drive and when I startup vista I get a blue screen of death !! But when I load XP it works fine. As any one encountered this sort of problem ? It really sucks I got to disconnect my drive to boot in Vista.
Thanks !
Francois G
Intel Q9550 @ 4.02GHZ
Evga 790i Ultra SLI
4GB Corsair XMS3 1600Mhz
2x Evga GTX280 SSC 1GB
Seagate 1TB HD
Antec 1000W PSU
Chieftec Dragon Case
Custom Watercooling Kit
Old July 12, 2008, 11:40 PM
Mibs's Avatar
Level up: 45% Level up: 45% Level up: 45%
Level: 12 - 226 points to level up
So what makes you think it is the optical drive that is causing the BSOD? Are you trying to boot into the different OSes using the disc or something? Not quite sure what you mean here.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 2 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old July 13, 2008, 10:51 AM
ipaine's Avatar
Level up: 67% Level up: 67% Level up: 67%
Level: 9 - 79 points to level up
I believe that he means that Vista works fine with the drive unplugged but blue screens when he has it plugged in, all the while it is fine in XP.
FrankyG, have you tried the newest firmware for that drive? You can find it at LG, here. Unfortunately I can't link it directly but using that page just select DVD-ROM (Writer) as the product and the OS to all, then use GH20LS10 as your subject. That will get you the firmware that they have for it.
At least that is where I would start.
Antec 900 - Asus P5N-E SLI - Corsair HX620W - Intel Q6600 @2.63GHz - Arctic Cooling Freezer 7 Pro - 4GB (2x2GB) Mushkin HP2-6400 @ 879Mhz 5-4-4-12
eVGA 8800GT w/Akimbo cooler SLI'd @700/1728/1000 -
Samsung SyncMaster 2253BW - Dell 1907FP - Vista/XP dual boot
Old July 14, 2008, 12:01 AM
Mibs's Avatar
Ah I see what you mean there, sorry my mistake. Working overnights constantly will do that to you...
