time for me to update too ... just dawned on me how much easier it would be to connect one into my caseless folding farm rigs when i need one for installing os'es, drivers etc. vs the ungainly ide cable. Other than my main rig, i just plug one in when i need it. |
Yep, just took the plunge myself and picked up the 18X Samsung Lightscribe model. Shows up as a DVD-RAM drive but everything seems to work well. Bundled software is Nero7 se and it works fine burning the lightscribe images. (My old nero 6 supposedly supported lightscribe but I could never get it to work with an HP lightscribe model). Seems relatively quiet as well.
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
picked one of those up from greenlymph in halifax a few months ago..didnt get any software with it though. Very quiet drive and looks tidy without the IDE cables to HD drive as well. Havent worked out if the drives working at SATA2 speeds though yet.
__________________ E6750/ Xeon 3350 DFI X38 LT 2 x 4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black). Loop 1: MCR 220 int. ; Apogee GT block. Loop 2: MCR 320; Swiftech Res.; 2x EK FC blocks. Pumps: 2x MCP655. |
SATA DVD drives are IDE with built in SATA interfaces. THey are no faster than normal IDE, they just have the a SATA adapter built into them. I do love my LG SATA DVD burner, mostly because I have PATA cables. It will be nice when they actually speed these things up enough to take advantage of the extra bandwidth though.
__________________ ASUS P5Q Pro w/C2D E7200 Mushkin Redline PC2-8000 2X2GB Visiontek HD 4870 512MB w/Dell 2709W BFG 680W LS ASUS Xonar DX2 w/Logitech Z680's Swiftech MCW655/Thermochill 120.2/Apogee GT/DD 4870 Coolermaster HAF 932/Vista 64 Ultimate |
I was close to buying a serial ATA DVD writer over the weekend. In theory, there's no justified advantage in using one, but in practice they are easier to manage without that fat 5cm wide ribbon floating around in your case. Besides, the price premium was only 5 dollars, and you usually only buy one or two optical drives at a time...
__________________ **Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP |
to see what drives are doing good you could check out cdfreaks.com. they seem to like the 20x samsung model. and apperently the Pioneer 212d is fully sata. if i am wrong then please correct me. |
don't see how it's lame. SATA is a connection type not a harddrive exclusive standard. I say it's about time they get more mainstream (saw them on NCIX like last year). No more screwin' around with master/slave crap for anything. That's a big plus if you ask me. I'm runnin' pre-rounded cables that are pretty much standard with new mobo's now. They still are a bit bulky and a pain to run (they bulk up if bent).
__________________ 3800X2@2.2GHz--2gb PC3200--200Gb Maxtor SATA2--eVga 8800GTS 320mb--eVga nForce4 SLI mobo--Klipsch 4.1--Antec nine hundred case w/Vantec 120mm on side--Vista Premium 64bit Join our Folding@Home team! |
I got a Pioneer DVR-212D in Black. Only 18x though. Seems to work fine, no issues with it so far. Haven't done much with it though. Nice clean bezel on it, pure black. No ugly white writing and such. The writing is "engraved" into the plastic.
__________________ Xeon Quad X3350 | 3.40GHz (Damn X38 chipset) ASUS Maximus Formula | BIOS RF0410 2GB Corsair Dominator | 850MHz 4-4-4-12-2T 2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T HIS ICEQ4 Turbo HD4850 @ 700/1200 X-Fi XtremeMusic Antec TruePower Quattro 850W Antec 900 [ HEATWARE ] |
| Quote:
So if its still ide internally then no point changing...no performance increase ![]() I'll just use mine till they go poof.
__________________ Cambridge,ON A8N-SL1 Premium AMD-Opteron 180 S939 X2 Toledo-"Denmark" @2.64Ghz. OCZ dual channel platinum 2gb. BFG 8800 GTS OC 4 wd satas/Samsung 2053BW Antec P180b/4 120mm tricools Seasonic S12 650 Vista Ultimate/XP professional 32bit |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Finally got an 8800GT | KnSKranky | Video Cards | 24 | January 27, 2008 10:17 AM |
| system completed finally | Rapid-X | CPU's and Motherboards | 4 | July 30, 2007 12:42 PM |
| Amd finally on track?? | cdn_Madrach | Press Releases & Tech News | 1 | July 27, 2007 10:55 AM |
| Finally Built!!! | Sameer | CPU's and Motherboards | 23 | May 17, 2007 05:49 AM |
