Old September 10, 2008, 05:09 PM
muse108dc's Avatar
Default Stripped down XP
Anyone know where I can download a stripped down version of XP for my Acer?
Old September 10, 2008, 05:30 PM
Jack Rabbit's Avatar
I have never seen anyone offering stripped down Winblows instillation packages for any kind of hardware. If you have a real install CD (not a image) you can use nLite to strip it down. Getting rid of the languages and unwanted drivers cuts it down substantially with little work or worry about compatibility issues.
- James Graham
Old September 10, 2008, 07:19 PM
JD JD is offline
There are various ones out there but nothing legal that I could mention/post links to here.
Basically just use nLite and do it yourself.
