Old August 21, 2008, 04:41 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
That link is old as the hills. I recommend Driver Cleaner...the NEW one. Guru3D no longer has the rights to host it as it is no longer free.
Old August 21, 2008, 06:57 PM
"Quote This..."
I've got driver cleaner pro.
Old August 21, 2008, 10:19 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Installed over 8.7 in vista 64 and 2x3870. Ran 3dm06 and vantage and all seems ok so far.
Old August 21, 2008, 10:31 PM
"Quote This..."
8.8 doesn't work at all for me. Total lock up on restart. One blue screen but mostly the screen shuts off. Did everything by the book, twice.
Cleaned out 88, now I'm back to 8.7, its working but CCC doesn't, says it cant start MOM.exe.
I hope I don't have to go through this every month.
~shakes fist at ATI~
Old August 21, 2008, 10:39 PM
Eldonko's Avatar
That's weird, working fine for me.
Old August 21, 2008, 10:53 PM
"Quote This..."
I did another clean and reinstall of the 8.7's and CCC is back working. Maybe the driver cleaner is doing something bad, I'll try and put 8.8 over top.
Or not, F this noise, 8.8 is slower in most apps and I'm tired.
Old August 22, 2008, 08:19 AM
Eldonko's Avatar
slower in which apps?
Old August 22, 2008, 08:53 AM
freaked's Avatar
i had to remove 8.7 before i could install 8.8, which is working just fine.
  #19 (permalink)
Old August 22, 2008, 09:19 AM
"Quote This..."
ATI Catalyst 8.8 Analysis - XP & Vista :: TweakTown
  #20 (permalink)
Old August 22, 2008, 09:24 AM
Eldonko's Avatar
I wouldnt say its slower in most apps.. it's close enough to be within MoE. It's pretty much the same other than gains in vantage.
see here XtremeSystems Forums - View Single Post - ATI Catalyst 8.8 Analysis - XP & Vista @TweakTown
