Old July 30, 2008, 08:32 AM
Default GeForce 177.79 beta for 8, 9 and 200 series
GeForce Release 177
Old July 30, 2008, 09:52 AM
Yah already have them installed and 1 thing seems to be fixed for me.. I hope .. I haven't seen it rear its ugly head yet.
For some reason previous driver releases I would lose desktop transparency and things would go black.
Yet to see this!
Old July 30, 2008, 03:05 PM
It runs BIOSHOCK in VISTA very untable for me - mind you I haven'T tried with a previous driver as this is a new system and fresh install - keep getting dumped to desktop with an instruction error cannot write to emory location 0x0000 type every now and then in BIOSHOCK.
Old August 1, 2008, 07:38 AM
magictorch's Avatar
Almost sounds like your GPU memory is overheating or is running at an unstable OC. Have you tried scanning the card for temps artifacts in ATI tool?
Old August 1, 2008, 07:41 AM
Chos3n's Avatar
Still no PhysX support for the 8800GTX I suppose...
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
CPU Intel Core i7 2700K 3.5GHZ
Motherboard ASUS P8Z68-V
Memory Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24
Video Card EVGA GeForce GTX 780
Sound Card ASUS Xonar DX
Old August 1, 2008, 07:52 AM
Mibs's Avatar
Has anybody tried these with the nvidia F@H client?
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old August 1, 2008, 08:21 AM
Card is perfectly fine.
And using these drivers guess what... No more problems with desktop transparency *cross fingers * * knocks on wood*
Old August 1, 2008, 09:47 AM
SugarJ's Avatar
I put these drivers on last night, I've got points today so it must be working.
Old August 1, 2008, 10:35 AM
Prof. Dr. Silver's Avatar
Yes, as a matter of fact I did! I just installed Vista cause I got sick of the 100% CPU usage while running both CPU and GPU F@H....Now CPU usage is down to 60%.
So after checking the F@H forums I downloaded the latest 6.12beta11 for the CPU and GPU and installed 177.79 drivers. No issues so far, no need to get that separate .inf file and PPD seem to have gone up by like 1100 points....on several different projects! It takes like 2,5 hours now for one WU whereas before it took like 6 hours! WOOHOO!
Looks like it's all positive! Haven't done any gaming yet though!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old August 1, 2008, 05:32 PM
GeForce PhysX support for more GPUs including 8 series will be available in August through a PhysX driver update.
