Old August 1, 2008, 05:36 PM
Originally Posted by magictorch View Post
Almost sounds like your GPU memory is overheating or is running at an unstable OC. Have you tried scanning the card for temps artifacts in ATI tool?
I haven't used the ATI tool however I've used GPUCaps and run it through a fur test with ALL settings maxed out, ran it for 3 hours solid and monitored my temps from time to time - the test puts 100% load on both CPU cores and the GPU at the same time, and visually I didn't see any artifacts, it didn't crash, the GPU, GPU ambiant and GPU memory temps were all fine - definately not an overheating issue in thsi case - I've run the FUR test, HDR, Shaders test, you name it, any memory errors or issues would have shown right away - I will give the ATI tool a try - I wonder why NVIDIA removed the GPU stability tester / artifact scanner it had in previous forceware driver....
