Originally Posted by Dr_BenD_over If I'm going from an Nvidia board to an Nvidia board or Intel to Intel, I don't bother re-installing if I don't have to, and with XP you usually don't have to.
Oh yeah, that gets done when I remember where to find the thing
I was getting seriously blocky video playback, which appears to be a Cat 8.6 issue. I tried WMP11 when it first came out and IIRC they removed key functionality that was present in 10, and made it so the Quicksilver skin from WMP9 wouldn't work anymore, which is the only decent one they have. Trivial I know.
It's not like I haven't given Vista a chance, I've been using it in one form or another since the betas, but I'll be sticking with XP Pro as my primary OS for a while yet I think. |
While it's great you don't reload your OS when switching boards, that's BS.
It's always best to reinstall a clean OS, or basically, expect problems, which you experienced.
I've tried that with XP before, as have others, & the result is often things getting effed up.
The fact you blame this on Vista is hilarious, but then again, you seem to blame Vista for everything that goes wrong on your system.
Can't remember how to turn off UAC?
Click on your user icon in the start menu...
And wtf again more blaming Vista for your DVD playback...i've been playing DVDs since RC1 of Vista OVER TWO YEARS ago without issues in Vista.
Not trying to be rude, there is enough nonsense in this thread i'm amazed people aren't choking on their own BS.
