It looks like an install log for some of your drivers. I assume D: is your DVD drive? Search all the discs you have fed it for the EIhlp0409.CHM or LICENSE0409.RTF files to see where they came from.
I think this is safe to remove. Best thing would be to just zip it up and save if for a couple weeks. If things go weird after you remove it then you can just put it back.
__________________ He either fears his fate too much, or his deserts are small, that dares not put it to the touch, to gain or lose it all.
- James Graham |
