Old January 12, 2018, 01:17 PM
On2wheels's Avatar
Question what's a good cheap & easy remote webcam viewing solution?
I want to setup a cam to check on my sump pump at home while I'm away, how would I do it?
Old January 12, 2018, 01:19 PM
I use a webcam and Yawcam but is reliant on the machine to be active. We have 2 setup to wacth our dog.
Old January 12, 2018, 03:19 PM
Mr. Friendly's Avatar
if you have power and a reliable WiFi signal there, there are a number of options in the $100 USD range.
Old January 12, 2018, 03:26 PM
I've done something similar to monitor a thermostat while I was away. I had good experiences with a Foscam IP camera bought from Amazon. The particular model I had isn't there anymore but they seem to have a few other relatively affordable options.
For remote access you can get a free dynamic DNS account from a service like No-IP (or you can skip that if you already have a static IP.) After that you can remotely view the camera from a web address or a phone app.
Easy to find cheap ITX mobo that OCs? igot6strings CPU's and Motherboards 6 May 25, 2014 11:49 AM
Good 5.25 to 3.5 HDD mounting and cooling solution? Killswitch Cases 1 August 9, 2010 06:54 PM
Remote Viewing Software Soultribunal O/S's, Drivers & General Software 14 June 12, 2009 12:54 PM
