Old June 26, 2016, 11:02 AM
Shadowmeph's Avatar
Default tinyMediaManager anyone use it?
I use Kodi on my PC and kind of sort of have my TV series and movies sorted out , today I was surfing around and came across tinyMediaManager https://opensource.com/life/16/6/tin...00000011jJaAAI
and was thinking of using that to sort through my Video selection but am wondering if anyone else uses it and if so what they think of it ?
Old June 26, 2016, 12:59 PM
lowfat's Avatar
I use Emby as my Kodi backend. It does the sorting, renaming, grabs metadata, and images.
Mael
Big Lian Li
Forever Alone
Old June 26, 2016, 01:11 PM
Shadowmeph's Avatar
Never heard of it I am going to check that out
Old June 26, 2016, 01:18 PM
lowfat's Avatar
It is rather fantastic. You can even start watching a show on your phone, stop it, then resume on your computer, HTPC, browser, or whatever.
Mael
Big Lian Li
Forever Alone
Old June 26, 2016, 05:14 PM
JD JD is offline
If you just want to rename your files, FileBot is pretty good. I use it as my "Run after" action on downloads.
Old June 26, 2016, 07:42 PM
Arinoth's Avatar
I use Sonarr to handle the backend, then Emby to just allow me to have an easier time sharing a database to my Kodi Pi machine or to my Xbone when the Pi decides to act up.
Here I am: here I remain
Old June 27, 2016, 04:09 AM
Sagath's Avatar
I use plex. I think it's fantastic.
Since a lot of you are using emby, I'd like to hear some pro/cons. Is it just because it's an addin for kodi?
