Old November 20, 2014, 06:59 PM
Alpine's Avatar
Default Adblock !!
Anyone of you have problem(s) with Adblock ? Mine dosen't block any pub since 2 or 3 days.
Have you the same problem as me ?
I don't know if its because that French dude from France who did write a code to bypass Adblock.
Thanks !
/alp
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
Old November 20, 2014, 09:16 PM
Shadowmeph's Avatar
personally I don't use adblock but I use ghostery because it gives me allot better control of what I am blocking .
is there any updates for adblock?
Old November 21, 2014, 12:08 PM
ShinraCorp's Avatar
It's possible that they did a bypass of Adblock. So until Adblock is updated there's not really a way to block ads with it.
Old November 25, 2014, 07:18 PM
Alpine's Avatar
sorry for late answers guys. Since my first post, i have install adblock Plus and also Ghostery which i like it very much. For now, problems solve. BTW, Ghostery is now all my computers at home and work !! Thanks
Main system
Server system
Old November 25, 2014, 09:03 PM
Shadowmeph's Avatar
I cery much like ghostery that is the only adblock I use it is great and once I figured it out was easy to use
Old November 25, 2014, 09:24 PM
Supergrover's Avatar
No Script is another good one, I use Adblock, Ghostery, and No script on all my rigs. The wife hated it at first but once you get everything setup (ie whitelists ) she wont go back.
R.I.P.
Old November 26, 2014, 10:35 AM
LionRed's Avatar
I use Disconnect and Adblock and they work pretty good. Don't even see ads on youtube (the skip after 3 or 5 second stuff ads, before video plays).
I will check out Ghostery...
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Old November 26, 2014, 10:49 AM
Bond007's Avatar
I am only using adblock, and have seen multiple ads in the last week or so. Time to try one of these other fixes.
