Old April 6, 2014, 02:07 PM
Bond007's Avatar
Some comments above aren't completely valid IMO, but overall I agree. I would also either go basic with a Linux box, or go win7 64bit. I wouldn't bother buying 32 bit anymore.
Old April 6, 2014, 09:05 PM
Shadowmeph's Avatar
Originally Posted by LHN91 View Post
32 bit limits you to 4gb TOTAL memory. That means that any memory on the graphics card deducts from the available memory. Honestly, if you have more than 3gb then 64 bit is the right choice.
not sure what that mean makes no sense to me .
but yes I guess if you are going to be buying an OS then buy 64bit but I would go for win8.1 that isn't using that stupid metro crap just install it with out using a Microsoft account . the OS is actually very good accept for Metro.
But if you are just doing simple things then go with linux it is free and pretty much bloatless.
I always use 64bit windows but that is becasue I have over 4gb ram as for gaming and or what ever the OS doesn't really mater and ram as far as I know doesn't matter or have anything to do with a graphics card but I could be wrong
Android Jelly Beans more Windows than Microsoft Windows 8 botat29 O/S's, Drivers & General Software 18 May 24, 2014 08:25 AM
Windows N Keys Work With Normal Windows? geokilla O/S's, Drivers & General Software 9 June 9, 2010 08:18 PM
Microsoft Windows 7 and Windows Live Mail shaman44 O/S's, Drivers & General Software 4 April 6, 2010 06:29 PM
Windows 7 Installation Problems: Stuck at Expanding Windows Fles flightsimnerd Troubleshooting 9 February 16, 2010 02:57 PM
Windows 7 Boxed Units Outsell Windows Vista by 234% FiXT Press Releases & Tech News 0 November 6, 2009 12:41 PM
