-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Windows 8.1 Pro and Display Adapter (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/64230-windows-8-1-pro-display-adapter.html)
r0k0 November 22, 2013 01:58 AM
OK, so got Win 8.1 Pro installed, ran great, automatically installed 326.60 by itself, now i just installed the 331.83 over it, and it worked until i did a reboot, after that says im back at 326.60
So, i used DDU ( Display Driver Uninstaller ) removed everything and once im booted back in windows i start the nvidia application to install 331.83 and give's me this
http://img38.imageshack.us/img38/8729/yvp7.png
Uploaded with ImageShack.us
Now im stuck and cant play a single game or change my resolution since i "" Dont have a graphics card installed ""
HELPPPP !!!!!!!!
Mars November 22, 2013 07:06 AM
Do you get anything if you hit "scan for hardware" in the device manager?
sswilson November 22, 2013 07:08 AM
You're using the stand alone driver right?
The only other thing I can think of would be to re-install your chipset drivers. Maybe there's a resource conflict of some kind going on.
r0k0 November 22, 2013 07:10 AM
It was fine until i uninstalled the 326.60
Drivers, same thing happened the first time i installed win 8.1
Also i didn't know their was a scan button
r0k0 November 22, 2013 09:36 AM
got it, my display driver was beeing read as Intel Xeon E1200 bla bla, uninstalled it in device manager and install nvidia drivers, tada !
Johnny Buntu November 22, 2013 10:03 AM
however
I have read many issues with the Windows 8.1 drivers stack, you will eliminate many headaches if you update all your chipset drivers.
Cheers
r0k0 November 22, 2013 10:11 AM
all chipset are updated
