Old October 20, 2013, 04:07 PM
Default Plex Help
I've setup Plex Media Server on my media server, and added content.
My girlfriends laptop can see Plex Media Server under My Computer, and is able to access any files perfectly.
My brothers desktop, and parents laptop don't see Plex Media Server under My Computer, like my girlfriends laptop has. However, it shows up under Network, but if you double click, all it does is open Windows Media Player.
My question is, how do I get the setup that is on my girlfriends laptop, to the other devices? I did not configure anything on her laptop for it to show up that way, so I'm a little confused.
Old October 21, 2013, 08:16 AM
Varroa's Avatar
We need more info like the OSes involved and the type of network you have running. Most of my PCs (Windows 7) the plex media server shows up in the networks tab as media server but in Windows XP that doesn't happen (I don't think at least).
GAMER: Win10 Pro x64, I7 8086K (corsair H110i), Asrock Z370 Taichi, EVGA GTX 1080 FTW, Gskill 4 x 8 GB DDR4 3200Mhz, Samsung 970 EVO 500GB M.2. NVME SSD, Western Digital Blue 1 TB M..2. SSD. Crucial M4 256GB, Mushkin 480 GB ECO SSD, HX750W, Sound blaster Z, & Phanteks Enthoo Pro M
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old October 21, 2013, 02:02 PM
JD JD is offline
Why not access it directly via your web browser? That should work far more consistently.
It should be http://computername:32400/web, or instead of using the computer name, you could use the IP address too.
G530 and plex w0z HTPC Systems & Software 2 January 28, 2013 07:21 PM
