Old October 11, 2013, 06:02 AM
trodas's Avatar
Question Forceware 162.65 WHQL display settings gone?!
For the second time on a fresh Windows 2000 SP4 install I tried install the Forceware 162.65 WHQL drivers. (Opteron 148, PNY 8600 GT - so the older drivers the better) The drivers itself work well, no question about it, however the settings are GONE FOREVER if I disable the icon in the taskbar.
I don't need and want to the icon be there, so I always disable it. And then the display options miss all the whole settings...!!!
And no, no way in hell clicking on the button bring them back. Nothing happens when I click on the button! It is just not working anymore!
Drivers continue to work:
...but I can't change the settings at all! This is very flustrating. Anyone know about some older good drivers that can handle 8600 GT and do work, instead of these WHQL fails...?
Or is there a way to fix this???
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
Old November 20, 2013, 09:28 AM
JohnWayne's Avatar
Don't know if you've solved this or not. Seems as though Nvidia Control Panel works from the system tray icon, but not from the button in Display properties.
Should be able to make a shortcut or run it from the Command line.
"C:\Program Files\NVIDIA Corporation\Control Panel Client\nvcplui.exe"
Other option is to check your registry. It's missing the link to know what that button is suppose to trigger, thus it clicks and does nothing.
Old November 20, 2013, 03:35 PM
trodas's Avatar
Talking
No, actually, the nVidia control pannel works from both places. But ONLY as long, as the tray icon are there...! If I close it, then by by nVidia CLP. It will never run. Ever. Period.
One guy at Guro3D forum even remember this nasty bug. But... I have a solution!
First at all, I started to use the Forceware 162.67 (since the WHQL 162.65 is obviously buggy) - and then I did not even touch the icon. What I did, was to end in the services the nVidia help service (from auto to manual for starting it) and then in StartupControlPannel I deleted all the nVidia added crap. On reboot, then icon was gone and the control panel still worked, when I click on it, then these prefs appear!
Hoooray!
...now why my POV 8600GT slow down to 1 frame per 10 sec after several hours of Quake 2 demo... (let's hope for just bad cooling spot, lol... caps are already exchanged on the little small cardie...)
Nvidia 320.18 WHQL Display Driver is Damaging GPUs rfglass Press Releases & Tech News 9 July 31, 2013 05:13 PM
NVIDIA GeForce Forceware 196.21 WHQL Drivers Released FiXT Press Releases & Tech News 18 January 22, 2010 07:54 PM
NVIDIA GeForce Forceware 190.38 WHQL Drivers fefox O/S's, Drivers & General Software 17 August 2, 2009 03:26 PM
NVIDIA GeForce Forceware 190.38 WHQL Drivers Released FiXT Press Releases & Tech News 14 July 21, 2009 07:47 PM
New Nvidia Forceware Drivers 182.06 WHQL LCB001 O/S's, Drivers & General Software 6 February 18, 2009 12:04 PM
