Old September 10, 2013, 01:10 PM
Default Converting .tiff to .pdf
Okay so my girlfriend bought a scanner so she can scan some files for school. She wants the files to be in pdf format and have them organized together in the sections they belong. The scanner will only scan them as .tiff . I did some googling and only found a bunch of links I dont really trust. I would prefer that the program be free (even if it is a trial or something) or at the least low cost.
Thanks.
Old September 10, 2013, 02:01 PM
IRQ Conflict's Avatar
Foxit.
Old September 10, 2013, 02:34 PM
What kind of scanner did she get? Even my old ass Canon 5200F does PDF scanning if I use the Canon Scan Tool (not the best software). If the bundle software really can't scan to PDF then try Foxit as suggested by IRQ. I used it just a PDF file reader and found it better than Adobe.
Old September 10, 2013, 02:37 PM
Thanks.
Scanners usually come with two options.
1) Using the scanner software via Windows
2) Scan directly off the scanner
2 usually will allow PDF scans but has to be configured in the software.
Old September 10, 2013, 02:48 PM
trodas's Avatar
Foxit PDF Converter
I did not have the plugin and for me, Foxit fail to download it, but that could be because I using version 3.0 build 1506, witch might be a bit outdated :) It probably works well in the more recent versions ;)
/me run and look where to obtain this plugin for older Foxit Reader
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
Old September 10, 2013, 06:40 PM
Nodscene's Avatar
I use Primo Free whenever I want to convert to PDF. Just print the file to PDF and you are done. Simple, easy, free, and no watermarks.
PDF Converter ? #1 Free PDF Creator ? PrimoPDF
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old September 10, 2013, 07:03 PM
sswilson's Avatar
Open Office also allows saving as (or is it converting.... I forget but it's pretty much the same thing) a PDF.
Old September 10, 2013, 09:31 PM
Forgot about OOO. Great software for free.
Old September 11, 2013, 06:03 AM
KaptCrunch's Avatar
Thanks.
I'm sure she can get a PDF software/license from school eg
if she got office Word has option to convert to pdf
Old September 11, 2013, 07:04 AM
Okay so part 2 of the equation, foxit will only let me save the image files as individual pdf which I have for the most part now completed (takes a while because they all need to be rotated individually and resaved). Now she wants me to take the groups of images that go together and save them as one pdf with multiple pages. I can't find an option to do that on foxit am I missing it or do I need another program for that?
Edit: Just found a video on how to do it in acrobat reader, I will give this a shot and let you know.
Converting a Heatkiller v3.0 1366 to 1155 Spblue Water Cooling 5 May 27, 2013 11:22 AM
[ARTICLE] Converting x16 GPU into x1 GPU Generic User #2 Video Cards 2 October 12, 2012 10:52 AM
DIY Project: Converting LP BBQ to NG dandelioneater Off Topic 7 June 6, 2012 07:12 PM
Audio converting software! GT7R O/S's, Drivers & General Software 4 September 13, 2011 02:25 AM
converting/opening old files JupiterTrooper O/S's, Drivers & General Software 5 February 24, 2010 11:40 AM
