Old August 28, 2013, 10:21 AM
Dr_BenD_over's Avatar
Fallen Folder
Default Atom 230 and Win7 Pro
How slow is this going to be? The XP Pro install seems to be borked, not really surprising considering how long I've had this system running for.
Atom 230 on Intel D945GCLF mobo
2GB Ram (maxed)
PCI Ati HD2400 256MB
500GB SATA2 HDD (WD Blue)
This system is only used to watch non-HD movies on my TV.
All's well that's Haswell
Old August 28, 2013, 10:57 AM
Soullessone21's Avatar
2GB Ram (maxed)
Honestly try windows 8 on it, I had a 330 with 7 that seemed slow but with 8 it was bearable
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
Old August 28, 2013, 11:09 AM
howpet's Avatar
You might even be happy with Linux Zorin. About as close to windows as it comes and a lot cheaper. Give the live cd a try.
Old August 28, 2013, 11:13 AM
Arinoth's Avatar
I never found my Atom 230 to be slow running Win 7 at all, though you could see if Win 8 will be gentler to it.
Here I am: here I remain
Old August 28, 2013, 04:47 PM
grinder's Avatar
i agree with soullessone21, you'll get better mileage out of win8 IMO. never liked win7 on any Atom I have ever used.
Old August 29, 2013, 03:53 AM
Fallen Folder
I'm gonna try Zorin as howpet suggested and the latest LTS version of Unbuntu which I'm familiar with.
Old August 30, 2013, 02:00 PM
if you're up for a challenge, you could try Arch linux, it's all about fast and light
Old September 13, 2013, 12:54 PM
sswilson's Avatar
Did you ever get around to testing this?
Reason I'm asking is that I noticed a big difference between XP and win7 32bit on a 2 Gig Atom N270 system. Not sure if it's something to do with win7's media player + Silverlight DRM but using media player I had a slight pause about 20 seconds from the end of every track and wrote it off as being an issue with an underpowered rig pre caching the next track for playback.
Fast forward to today and I've got XP installed on the same system (to sell it on kijiji) and it's not exhibiting the same behavior. If it keeps this up, I just might keep the bloody thing as a media server...... :)
edit: Hrmmmm........ seems like I wasn't the only person having the issue with win7 but that Microsoft decided to remove the thread.....
WMP 12 makes pauses towards the end of each track - Microsoft Community
Old September 13, 2013, 06:18 PM
Fallen Folder
Testing it became a mute point when I finally decided to upgrade my main system, I'm just going to replace the ATOM with a Q6600, that'll run anything.
IBM Atom movie clshades Off Topic 0 May 1, 2013 04:38 PM
Need to replace my Atom 230... Dr_BenD_over HTPC Systems & Software 3 October 21, 2011 09:38 AM
[FS] M-ITX PC VERY SMALL ATOM 330/945/X1300/2GB/DVD/WIN XP b1lk1 Buy/Sell & Trade 0 April 1, 2011 07:01 PM
New Atom cpu [Anandtech] gingerbee Press Releases & Tech News 0 December 21, 2009 08:06 AM
Up and ATOM Dr_BenD_over Case Mods, Worklog & Gallery 17 November 26, 2008 04:43 PM
