Old August 28, 2013, 08:39 AM
Default What should I use
My pc D101GGC does not have a driver for windows 7 and windows 8 so which Xp should I use for better performance and graphics.
Old August 28, 2013, 08:57 AM
A new computer.
Old August 28, 2013, 09:13 PM
WEll that's a lame answer. Can't i teak it a little and make it awesome.
Old August 28, 2013, 11:23 PM
It's not a lame answer, it's a realistic answer. There's really only 1 XP you can use and it's the XP Pro 32bit edition. 64bit XP got very little driver support to start with so it's a non starter. You can switch to any flavor of Linux and see if it's any better but P4 these days are e-waste more or less. What do you mean by better performance and graphics anyway? What are your goals exactly?
Old August 28, 2013, 11:51 PM
have you actually tried win7 on that board? maybe drivers aren't provided because they're included in the OS already which is pretty typical with older hardware. I wouldn't expect it to be a speed demon by any means though....
Old August 29, 2013, 10:17 AM
Shadowmeph's Avatar
have you tried the windows 7 advisor it will scan your pc hardware for now driver issues
https://www.microsoft.com/en-us/down...ils.aspx?id=20
